Question about Radio Communications
Icom ic51e dup error - Radio Communications
OVER V error ON ICOM IC-A24 when power UP ?
Sorry to say, but normal. As long as radio works fine otherwise don't worry about the error display.
Nov 30, 2013 | Icom IC-A24 NAV/COM Transceiver
When I install BMW ICOM software in English, it works well, but when I choose Spanish, it display errors.
Except English, German and Chinese, if you install BMW ICOM in the other language, you will get the same errors.
Mar 14, 2013 | Cars & Trucks
IC-A210
I can to see on Panel Screen ICOM IC-A210 message RX error
Feb 01, 2013 | Icom IC-A210 VHF Airband Transceiver
How to find icom bc-177 sofware ?
I'm totally confused by your query my friend...
You have an Icom desk top charger, do you have the Icom radio that goes with it?
Software for hand held Icom radios is can be available, but for the Icom battery charger, NO is the answer.
Cheers,
Peter
Jul 08, 2012 | Icom BC-177 Desk Top Charger
HP 48GX Says "DUP Error:
Do you have anything on the stack? The DUP function duplicates the top element of the stack. If the stack is empty then you'll get this error because the calculator can't duplicate nothing.
Aug 22, 2011 | HP 48gx Calculator
Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Sep 06, 2008 | Icom IC-R5 Handheld Scanner
About formula
One way of finding (and removing) duplicate entries is to sort the column and put a simple formulate in a temporary column next to that column; for example - if column A has duplicates, insert a column (B) and starting in B2 put if(A2=A1,"DUP",""). Select B2 and scroll down to the bottom of your spreadsheet. Press <ctrl>-D to extend the formula in B2. Wherever there is a duplicate you'll see "DUP" in column B. If you want to remove the duplicates copy column B and Edit / Paste Special... with "values" selected (to wipe out the formula). You can then sort the spreadsheet on column B and remove rows with DUP in column B.
If you can't delete the duplicate rows and the order is important first include a column that captures the order - same trick except put row() in that column, copy / paste special the values and then you can re-sort after doing the above to have both the DUPs marked and the original order.
Hope that helps.
Aug 08, 2008 | Microsoft Computers & Internet
Radio Communications Logo
27 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
