Question about Nemox Gelatissimo Ice Cream Maker
The churner blade stopped while making ice cream and will not will not move so we can use it again.
Does the paddle in the cuisinart Ice 21 ice cream maker suppose to move
yes, the paddle moves to stir the concoction and make it into iced cream.
Mar 31, 2013 | Cuisinart ICE-21 Ice Cream Maker
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Richmond Ice Cream Maker blade for Model 78 4 quart
I am need of a new can for my Richmond ice cream freezer model number 78 that a 4 qt. please help me to find this. It is electric.
Mar 09, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Ice Cream not freezing
Yes, they stop working sometimes. Same thing happened to me.
The Cuisinart ICE-20 bowl is precisely the same, and works with the Krups 337. You can buy the Cuisinart bowl separately. It costs nearly as much as the whole machine, but what can you do.
Jun 26, 2008 | Krups 358-70 La Glaciere 1.5 Quart Ice...
Blade stops turning but motor still running
Hi Lew 2!
Sounds like the belt might be slipping prematurely. I'd try cleaning the belt and all the pulleys with an alcohol based solvent or rubbing alcohol (clear) to remove any excess oils that might cause slippage and see if that helps Is there any type of belt tension adjustment? If so, also try tightening the belt.. If the problem persists, you probably need to replace the belt.
If this helps, after the churning stops, remove the paddles and cover the top with plastic wrap or wax paper and allow the mixture to "firm up" in the ice bucket nother 10-15 mnutes, and then enjoy a great old-fashioned treat!
Hope this is a help, let us know how it goes, and good luck!
-WB
Jun 14, 2008 | Simac Ice Cream Makers
Mixing Arm Doesn't Turn
As long as it makes the ice cream, it doesn't matter which one turns. If it's not making the ice cream, call Cuisinart, as both the lid and the mixing arm can be replaced.
-Tha Mp3 Doctor
Jun 04, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
MOTOR DRIVE DOES NOT TURN
Dear Dannyvk,
I am having exactly the same problem with my rival 8200 ice cream maker. It worked once and stopped usual, when I first used it. The ice cream was wonderful.
However, when I started to make a second batch, the ice cream maker just hummed after I plugged it in. No movement of the pin/hub whatsoever. I tried to move it, by placing the steel can on top and moving it side by side. I plugged it in again, and experienced the same old humming sound.
Is it a fuse? Is the motor blown? Is this something that a small appliance dealer can repair at a reasonable cost? Can anyone help? I am so disappointed!
Faithful in Christ,
D.
Mar 12, 2008 | Rival 8210 2 Quart Ice Cream Maker
Nemox Gelatissimo Ice Cream Maker Logo
43 people viewed this question
Top Nemox Ice Cream Makers Experts
Colin Stickland
Colin Stickland
ray gallant
Are you a Nemox Ice Cream Maker Expert? Answer questions, earn points and help others
