? 9:52 https://www.youtube.com/watch?v=bUV6BZfVxDY
Jun 15, 2011 - Uploaded by 1A Auto Parts
1A Auto shows you how to repair, install, fix, change or replace a broken .... The outside door handle is broken on my HondaAccord and the child ... How To Install Replace Broken RearOutside Door Handle 1996-00 Honda ...
www.automotiveforums.com > ... > Isuzu > Rodeo ' Passport ' MU Can't open rear door Rodeo ' Passport ' MU Car Forums. ... The driver side rear door on my 95 Rodeo won't open. ... You can remove the door panel without opening the door. ... I've got a 96 Rodeo and the DS RR door was stuck as well. ... I went to aHonda dealer (lack of ISUZU dealers in my area) to get the part, it only ...
? 0:19 www.youtube.com/watch?v=xHX6Up7HCfs Jul 2, 2006 - Uploaded by SadieSummer
How to drill open a honda door that's stuck or won't open (no real info on .... How To Install Replace Broken Rear Outside DoorHandle 1996-00 ...
How to Open a Honda Door that's STUCK! ... How To Install Replace Broken Rear Outside Door Handle 1996-00 Honda Civic - Duration: 5:47.
Honda Passport driver door lock stuck Questions & Answers ...
www.fixya.com > ... > driver door lock stuck > Cars & Trucks > Honda Honda Passport cars & trucks driver door lock stuck questions and answers. Ask your ... 1996 honda passport defrost has stopped working ... dash vent ... Back seat doorsdo not open ... stuck. Any ideas of how to get them to open? It seems that ...
You should be able to operate window from main front switch regardless if rear switch is bad. If it does not work from rear door or front door, it is probably not the switch, but the window motor which do go quite often. Take switch and verify it is working by testing with volt meter, next, check to see if you have 12VDC at switch, could be a broken wire, another common problem with older cars.
CeraCoat-NanoTech.com
This is what you do take the door skin off of the inside of the door and at the top corner there will be i think three nuts and than your going to need door clips after your done in order to put the door panal back on
CHECK FOR BROKEN WIRES BETWEEN DOOR AND DOOR POST..THERE WILL BE A RUBBER BOOT IN BETWEEN DOOR..WIRES TEND TO GET BROKEN IN THESE FROM DOORS OPENING AND CLOSING..THIS WHERE I WOULD START LOOKING
Check for power to your rear wiper motor. To do this you will have to remove the rear door trim. Once the door trim is removed check for power at your connector plug on the rear wiper motor with switch on. If there is power there than replace motor if not then start by checking fuses (which is a good idea to do before removing door panel because it's the easiest thing to check), connectors and wiring for damage and open circuit( cuts or broken pins in connectors or open/broken wiring)
i pulled on the back door latch lever and it broke,now i can not open the rear door,it's a black handle lever please help me to find it as soon as possible
sound like the link for the handle is broken.
you should have a pull handle near the floor at the driver seat.
if you can open the door with the pull handle. then the link to the latch is broken.
what you need to do is open the rear internal panel to get access to the latch.
