Question about PENTAIR WATER Pentair Sta-Rite DynaPro 1HP
Well pump losing prime
I have a Sta-Rite Pump model M8E-7 Motor# C48L2FC4 3450 Rpm HP1 115/230v. We are having to prime the pump almost every other day, it might last week. Is there something I can do to make it keep its prime? Or is there something I need to change out?
    Sergeant:
  • 191 Answers
You might have a leak in the foot valve, you can try installing a check valve several inches before the intake to maintain a prime, or check and clean/replace the foot valve.
If the pump ran dry, check the inlet fitting. the pump can get hot and melt pvc piping connected to it, causing air to leak in the inlet side.,
Posted on Sep 26, 2014
Do u have to prime all pumps
YES all pool pumps need to be primed, failure to do so will destroy the shaft seal AND could cause serious damage to the pump and motor. starving pumps is bad also. Make sure they have water, it makes them happy.
Apr 28, 2012 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glas
Prime the pump after any repair
Jay the pool pump reapair guy in longwood Florida 32750
Mar 12, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Need bearing within PN C103-137P1 , higher assembly would be P2PA50-120L
most of these are 6203 2rs c3 bearings used in this motor. here is a picture on how to remove your pump for service, i would suggest professional repair to avoid extra costs.. just search your area for yoour local pool pump motor repair guy..remember to prime the pump after any pump repair ..jay
Sep 21, 2010 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Jul 10, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Feb 08, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
PENTAIR WATER Pentair Sta-Rite DynaPro 1HP Logo
744 people viewed this question
Top PENTAIR WATER Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a PENTAIR WATER Water Dispensing and Filtration Expert? Answer questions, earn points and help others
