Question about Fisher and Paykel E522BRXU Fisher & Paykel 17.1 cu. ft. Stainless Ice & Water Right Hinge Refrigerator
Repair manual for a fisher and paykel fridge model e522brx
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
SOURCE: Fisher & Paykel Model #E522BRX Fridge portion not working but Freezer OK
I bought this nice looking fridge 4 years ago and after 18 months the fridge part was warm and all the food had to be thrown away. The freezer part was still working.
I called the store that I bought it from and they told me to call a recommended service company. When I called they said that there was a common problem with the fan breaking down. (The fan is what makes the fridge cool as it blows the cold air from the freezer up to the fridge).
They did not have the part in stock and said it would take 6 weeks to order it from New Zealand!!!
I called the store back and had made a commotion so they replaced the fridge with a new one.
Now after two and a half years the same thing has happened again. I called the store and asked if this was a design flaw and did they have a recall on them, but the person I spoke to claimed that they have sold very many of these models and no one else has the same problem.
I am 65 years old and have had quite few refridgerators and none of them has ever broken down at all. I believe that the same problem of the fan breaking again is a design flaw and should be fixed by the manufacturer.
It seems like many other people have the same costly repair problem with these models. I would never buy Fisher & Paykal again!!!
Posted on Jun 11, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
Fisher & Paykel fridge the water dispenser on the front of fridge is locked how do you unlock it.?
Hello Patti Emelson,
Let's say... (for example)
Your model number is E522BLXU...
on that model... (Fisher & Paykel)
Page 10 of those
instructions
says of manualslib.com (URL link below)
Dispense LOCK
This mode disables the water dispensing pad & prevents water
from being dispensed.
To activate this mode, press the MENU and MEASURED FILL
keys together for two (2) seconds...
Of course the precise buttons could vary... WHICH is why
putting in TOUR MODEL NUMBER is important for
such questions ...
Reference
Fisher Paykel E522BLXU Service Manual Dispenser Lock Key Presses measured...
Hope this helps
Carnac the Magnificent
Oct 21, 2017 | Fisher Refrigerators
Tip
Fisher Paykel Fridge E522BRX Not cold enough !!!
After one year, I just found out that the temperature setting works the opposite way of other "american fridges" The temperature control is like a termometer so, when you think you put it colder up the thermometer...is goes warmer!!@#$%%!!! Was I ever dumb???
on Sep 05, 2013 | Fisher and Paykel Active Smart E522B...
Freezer working fine, fridge not cooling. Left to defrost last night, turned back on this morning and all seemed fine. Fridge was cooling and seemed to be running all ok. Tonight the earth leakage keeps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Fisher and Paykel E522BRX Bottom Freezer...
Fisher Paykel E522BRX refrigerator not cooling but freezer is working.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Fisher and Paykel Active Smart E522B...
REFRIGERATOR WILL NOT DEFROST
heatman101
Aug 30, 2010 | Fisher and Paykel E522BRX Bottom Freezer...
Hope I'm not too late - I had EXACTLY the same problem and the freezer fan wire was broken. I fixed it an documented everything in http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf. Good luck.
Aug 14, 2008 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel E522BRXU Fisher & Paykel 17.1 cu. ft. Stainless Ice & Water Right Hinge Refrigerator Logo
122 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
