Question about Pioneer DEH-150MP
Can i hook these wires up to external amp
No preamp wires
No sound on phillips 32" lcd tv, got pic, get sound when hookedd up to my laptop
The audio amps have shut down but the preamps are still functioning.
Fixing too expensive. simply hook it up to external amp via the audio outputs on tv.
Aug 30, 2016 | Televison & Video
How do I hook up 2 preamps for the front right and left 1 for each channel on a Marantz SR6007? Can I even do it or am I just allowed 1 preamp for the fron right and left channel?
Hi Mark,
One can hook-up as many peamps as desired to the SR6007 either as sources or destinations. How to connect external preamps to the SR6007 depends on what you wish to achieve.
The SR6007 already has its own internal preamps.
You could, if you are not careful, burn the AVRs input circuitry by adding external preamps as "sources". Also, not much improvement in SQ could be gained by external preamps connected to the SR6007's preouts becuase any signals that come out of these have already been processed (or distorted?) by the SR6007s internal preamps.
Jul 31, 2016 | Marantz Audio Players & Recorders
It started when a guy tried to hook up my radio so what about factory amp
Still need to know what the problem here is. To address the amp issue is easy. Most factory installs use only the amp that is built into the radio deck and do not have an external amp. If you do have an amp...which would be a higher end factory install then you are using your deck as the preamp and then going to the amp. You need to find that amp for the hook up.
Dec 29, 2015 | Cars & Trucks
How to change 110v to 220v on sonance cinema 260 subwoofer amplifier
I suggest contacting the manufacturer as there may be an internal "reconnect" that would allow 220v operation. Good luck!
May 21, 2014 | Audio Players & Recorders
HOW DO I USE A EXTERNAL AMP LIKE A YAMAHA M-85 FOR MY CENTER CHANNEL ON MY RX-Z11 AV AMP
You should have preamp output jacks on the back of the receiver. Hook that up to your external amp input.
Jul 24, 2013 | Yamaha RX-Z11 11.2 Channels Receiver
How do i hook up a amp to this player
This particular head unit has a built in amplifier for the cars speakers. Unfortunately it does not have preamp RCA outputs which means to use an external Line out convertor. These are easy to find on crutchfield.com, any local car audio shop, or best buy. Once you receive your LOC it will have instructions telling you how to connect it. Generally you will tap it into the speakers High and Low wires, a remote wire (ignition signal), and a ground connection. The RCAs will be supplied out of the back of this device ready to be hooked up to your amplifier.
Apr 30, 2011 | Clarion VRX745VD Car DVD Player
Looking to hook up an audiosource EQ100 to an a sony cass deck
Simply place it in line with the analog input. Or install it in a Tape Loop on your integrated amp/receiver and attach your tape deck to ITS tape Loop.
Ins to Outs
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
Be advised, using analog processors on digital-capable multichannel elcetronics will only work for analog 2-channel sources.
Mar 05, 2011 | AudioSource EQ-100 Home Equalizer
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Feb 16, 2009 | Bose Car Audio & Video
Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Sep 07, 2007 | Audio Players & Recorders
Pioneer DEH-150MP Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
