Question about Philips WACS700 Shelf System
How to format new wacs700 new hdd install - Philips WACS700 Shelf System
How to format LG Laptop Model No LGS 53
If you are installing a new OS on the primary HDD you will see in the install Format HDD. If not , remove HDD and format.
Feb 04, 2013 | Computers & Internet
How to replace hard drive
Hi, everything you need to know about to replace the HDD on Philips WACS700 can be found here: http://www.scribd.com/doc/12808150/14051wacs700-How-to-open-Philips-Streamium-WACS700-courtesy-of-AndrewT
I have done this myself and must admit that it is a bit fiddly. You need to be a bit handy, know your way around with electronics and have access to screw drivers/soldering equipment and electronics pliers.
Good luck.
Dec 09, 2012 | Philips WACS700 Shelf System
I've bought a new PC running 64 bit Windows 7, and my installation disk won't load. Anything that can be done?
Yes if you have the Phillips WACS700 and want to install the software that came with the system to upload/download music and you have a windows 7 or Vista you need to open the explorer and go to the CD/DVD folder then look for the .exe change the properties of the .exe files to run in compatibility mode "compatible with Windows XP SP2", then run them from the explorer. I have a Win 7 computer and both software that came with the CD did not wanted to run because they required XP, as soon as I change the properties of the files they ran and installed without a glitch, everything worked as it should and I been able to enjoy my music on the WACS700.
Nov 12, 2010 | Philips WACS700 Shelf System
I have a wacs700 which will not boot up. Any suggestions.
Hi,If your system's screen just display ''booting up please wait'' Your hard disk is corrupted.In this case the hard disk should be replaced.But first the installation of new hard disk of the original program I mean the image of the old hard disk.If you find that image and install a new hard drive will solve the problem.
Apr 19, 2010 | Philips WACS700 Shelf System
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
How do i format my novatech B750
Just use a bootable CD and boot up with it, you'll come to a stage where you're asked to format your HDD.Or bootable flopy disk, when in command prompts you type format e: and press enter Or you could remove the HDD and use a external USB casing and use other PC to Quick format your HDD. Note:If you're trying to format your Laptop HDD, I will suggest that you get the all driver information for the hardwares before installing a new operating system. Because when new fresh installation is done you will be asked for the drivers for CD-rom, key board etc...
Nov 13, 2008 | Computers & Internet
I need to format my hdd of my dell latitude d600
please specify wt exactly u r facing ??
do u need any new disc ??
or software to format ur hdd??
email erpenny_varun@yahoo.com
May 19, 2008 | Dell Latitude D600 Notebook
Wacs700
From HDD mode on the centre, press menu and select "Station Management".
If the option is available select "Delete Station" and delete any stations listed.
Select "Add New Station" and the unit will start searching.
On the station press menu and select "installation mode"
If this option is not available, try from another source setting, such as AUX.
Once the centre has found the station, press stop on the centre, as the station cannot connect until the centre has stopped searching.
If this doesn't work, you will have to reset both units to factory settings and start again.(Menu -----> Settings ------> Restore)
Feb 23, 2008 | Philips WACS700 Shelf System
Source+Stop doesnt fix it
i had this problem, what i did was to take the front of the center console and thee was a cable not conected. The cable becomes loose after you remove the front and is a pain to get back on
Dec 21, 2007 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
