Question about Montgomery Ward Sewing Machines
Where are gears in sewing machine - Montgomery Ward Sewing Machines
My decorative stitches are not sewing. The machine sews straight okay but the thread does not catch with the decorative stitches.
there could be a problem with the gear for the decorative stitches, the machine may need to be checked to see if there is a gear or gears damaged or broken
Apr 06, 2015 | Elna Quilter's Dream 6003Q
Why will the bobbin race assembly on my singer touch and sew 640 will not move?
This specific model, and most of the Singer Touch and Sew series of machines has several plastic gears that drive either or both the hook, and the feed dogs. Due to age and general wear, these gears eventually break. It is almost 100% likely that one of your gears is broken. It is recommended that you replace all of the plastic gears in your machine at the same time. If you just replace the one broken gear, you are merely shifting the weakest point in the system to another gear, which will also break shortly. If you replace all the gears at once, they will be of equal age and strength. It is best to get this done at a reputable sewing machine repair shop, as this repair involves a complete re-timing of the machine, and can be quite difficult for the novice.
May 06, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Singer 401A gears will not move. I can wind bobbins all day but the gears to sew are frozen they try to move but will not.
the gears or some part in the sewing machine could be damaged, I suggest having the machine checked to see what is wrong inside the machine hindering it from sewing.
Aug 21, 2013 | Singer Sewing Machines
Broken sewing machine gears
if the machine has a broken gear then they have to be replaced or get another sewing machine
Feb 26, 2012 | Janome Mini Compact
Where are oiling points--I have original manual & it doesn't indicate where to oil.
there are some sewing machines that are self oiling, the gears are soaked in oil & when the gears get warm or hot enough then the oil come out from the gears & oils them
Oct 07, 2010 | Janome 2049LX Mechanical Sewing Machine
My hook gear has gone bad, I have singer sewing machine model # 834, I need help with how to take the parts off and replace them
http://www.sewingpartsonline.com/singer-834-sewing-machine-parts.aspx
Follow this link, click on the hook gear parts, and you will see a link to a video showing how to install these gears. I was able to follow this video and replace the gears on my old machine. For me it was do-able, but moderately difficult. If you think you're up to it, go for it. Replacing all for gears a t once will cost $50. (Singer 834).
Sep 16, 2010 | Sewing Machines
My Elna automatic TYPE 41C plastic drive gear has shattered. I ned a new gear
You can obtain one of these from www.sewingpartsonline.com, not sure if you mean the cam stack gear or the hook pinon gear down under the rotary hook but both are available, liks are http://www.sewingpartsonline.com/cam-drive-gear-elna-416340.aspx
or http://www.sewingpartsonline.com/hook-drive-gear-elna-star-11-sewing-machine.aspx
If you want to install yourself you may want to join the Yahoo group Elna Heirlooms, they share lots of information there on these Swiss made Elnas.
Jun 11, 2010 | Elna 2005 Mechanical Sewing Machine
A plastic bevel gear has broken and the material
You can get the gears quite easily on ebay, they are standard on all singer machines
Nov 21, 2009 | Singer 5070 Mechanical Sewing Machine
How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Mar 02, 2008 | Sewing Machines
Sewing Machines Logo
15 people viewed this question
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
NOEL
NOEL
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
