Question about Garden
Snowthrower will only keep running if primer is pushed
    Scholar:
  • 128 Answers
Sounds to me your main jet in carburettor is blocked .have carburettor jet cleaned this will solve your problem .
Posted on Apr 21, 2014
  • 109 Answers
SOURCE: Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Posted on Apr 21, 2009
  • 376 Answers
SOURCE: 158cc yard machine, starts then dies.
Your fuel tank and carb need to be removed, both cleaned and replace pump diaphragm between carb and tank. If you want to do it yourself, let me know and I;ll tell you how. Not a difficult job. Dwain
Posted on May 26, 2009
al_kupchella
  • 843 Answers
SOURCE: KEEP GOING ONLY IF YOU KEEP PUSHING THE PRIMER BUTTON
You have a clog in the gas flowing into the carburetor. Get some carb cleaner (the spray kind is fine). Drain or siphon the gas out of your mower and discard. Put a little fresh gas and a little carb cleaner in the tank. Run it through. Do this a few times if necessary. When you get new gas, add a gas stabilizer like Sea Foam.
Posted on May 05, 2010
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
SOURCE: I have a Yard Machine snowthrower that starts then
you need to remove the carb from the engine, tear down(don't worry they don't have many parts inside) and soak and then use carb cleaner or compressed air to blow out the ports insind the carb. this should solve your problem.
Posted on Nov 27, 2010
Ariens 5520 snowthrower only runs if i rapidly push primer button
check for cracked fuel line.
Could be sucking air in with fuel starving engine of fuel.
Does float in carb operate correctly?
Float maybe full of fuel.
Feb 14, 2014 | Garden
Gas leaking from carburetor bowl drain screw when pushing in primer. Push primer two times and couple drops of gas on floor. Any way to tighten spring screw on carburetor bowl?
Sounds like you need a gasket on that screw. Don't over tighten as you could mess up the threads. I think this is the screw that has the
fuel jet in it. If you take it out its good to clean out that jet as well to have a good running machine.
Jan 05, 2014 | Mtd Snowthrower 208cc 26"
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
I have a briggs and straton 6.75 lawn mower the only way i can keep it running is to push the primer, it will run for a couple of seconds then die if i don't push the primer,how do i adjust it so it...
Hello
Obviousy it sounds like a fuel problem...I would suspect air shiponing in through a fuel line.. or if a diaphram type fuel pump it may need to be replaced.
Jun 12, 2011 | Garden
I have a Yard Machine snowthrower that starts then shuts down in a few seconds. I can keep it running if I push the primer button when it starts to die...any suggestions? I have: drained fuel and put in...
Nov 27, 2010 | Garden
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Procedure for starting
Thats called the primer Make sure the on/off switch is on the on,Push the primer at least 4 to 5 times,then pull it..once it starts you may have to push the primer a few more times to keep it running once it runs on its own and you dont have to push the primer to keep it running Cut Away,Also one more thing you probably already Know make sure its full of bar oil..Hope this helps you and have a great day...
Apr 06, 2009 | Garden
Apr 05, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
