Question about Janome 2212 Sewing Machine
Sewing machine balance wheel jam - Janome 2212 Sewing Machine
How do I get the wheel off an old Singer sewing machine model 66
If you are talking about the Balance wheel on the od Singers it is fairly easy.
You first need to remove the small screw in the clutch ( which is the chrome knob in the middle of the balance wheel) Once this is removed you can completely unscrew the clutch and then remove the balance wheel
Sep 16, 2014 | Sewing Machines
Why is my machine jamed
Sounds like a thread jam ! Open bobbin case housing remove bobbin and clean away thread ! Do not force the balance wheel to turn or you will knock out the timing !
Aug 25, 2014 | Tacsew 20U43 Sewing Machine
Balance wheel doesn't turn
Don't force it. open up under the presser foot and the bobbin area.... pick out any threads.
Sep 01, 2012 | Janome L-344 Mechanical Sewing Machine
My kenmore model 385.12912 sewing machine is completely jammed...Need help. ...............milt
You need to take the bobbin case and the raceway out to seek out the piece of jammed thread, before you do that force the balance wheel backwards that may free it off.
Sep 13, 2011 | Kenmore Sewing Machines
My singer 2500 has the needle jammed
Undo the needle clamp and turn the balance wheel backwards slowly and take the needle out, then check for jammed thread
Aug 12, 2011 | Singer Sewing Machines
Needle doesn't move, the balance wheel is very hard to turn
Sounds like it is jammed with thread or fabic. Totally rethread your machine and clean out your bobbin area. Then try turning your wheel towards you. If, you do not have your manual to check, go to www.sewingmanuals.com and download one for $10. If that doesn't do it, all you can do is take it in for service.
Sep 19, 2010 | Janome L-344 Mechanical Sewing Machine
Balance wheel on my sewing machine LS 2125 is jammed up. what do i do
Always turn the handwheel towards you, never away because you can mess it up. Check your bobbin area to be sure there is no lint, cloth etc jammed in there.
Sep 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
The machine won't sew. the motor runs, but the stitches won't form. I have put the clutch in
If the needle is not going up and down the belt may be slipping or even come off, disengage the stop motion and see if the balance wheel turns as if to wind a bobbin, if it does then something must be jammed in the bobbin case area.
Nov 01, 2009 | Kenmore 15516 Mechanical Sewing Machine
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Janome 2212 Sewing Machine Logo
27 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
