Question about Garden
Yanmar 186f diagram
Rebuilding a 186f engine for a generator for elelo school solomon islands.i need to know the cylinder head torque urgently
  • 7 Answers
SOURCE: rocker clearences
the book says 4-6 I always set them at 5
Posted on Sep 05, 2008
wireguy212
  • 1627 Answers
SOURCE: Hello, does anybody know the torque setting for
I found the tech manual one lin but it can"t be opened since deere is updating it.I will see if we have the book"tm1974" at the dealership in the morning and get back to you.
Posted on Oct 28, 2009
lothos
  • 14 Answers
SOURCE: what is the torque settings for the head of a
15 ft# then 30
Posted on Jan 18, 2010
vanherringto
  • 1738 Answers
SOURCE: Request the cylinder head torque
Here's a link to the head torque specs of all engines. The Yanmar 6HAL DTN should be there as well. Scroll towards the bottom of the page to view the information you need.
http://www.aera.org/downloads/Torque3.pdf
Note: Click the + sign in the magnifying glass at the top to enlarge the information. This web page is in PDF format and may take a minute to load on your computer. Be patient.
I hope this helps.
Posted on Jan 25, 2011
  • 252 Answers
SOURCE: looking for cylinder head and connecting rod
hi there
pauly 46 here
for your information required see the download of service manual from below
http://www.scribd.com/doc/3852484/K582-Service-manual
but i have the required settings for you in the mean time cyl hd bolts 35 ft /lbs
and con rod bolt torques 5/16 " use 200 in/lb torque
or if 3/8 bolts use 300 in/lb torques
service manual is 92 pages long but helpfull
cheers hope it hepls
pauly46
Posted on May 03, 2011
2005 TOYOTA HILUX KUN25R DIESEL ENGINE TORQUE SPECIFICATIONS
Hey
As i know you face a lot of problem.Due to this I give you one mail address it really help full for you.Please visit it.
May 03, 2016 | Toyota Cars & Trucks
Looking for cylinder head torque for a yanmar 4tne94 engine please
cylinder head torque for a yanmar 4tne94 engine in your google browser and a service manual choice will come up.
Sep 26, 2014 | Cars & Trucks
What is the torque for a 1983 mazda 626 fe sohc engine
go to autozone.com and login or set up an account if you don't already have one it's free. Then you will be able to punch in the year make and model of your car and find repair manuals for any vehicle you desire. In your case 83 mazda 626. and go to cylinder head info and there you will find what your looking for. Good luck.
Jun 06, 2014 | 1983 Mazda 626
Correct pressure for torque the head of mazda pickup 1998
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8 ' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51 Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final tighten all bolts an additional 90 to 100 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 ' ' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' ' ' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs Step 3: turn cylinder head bolts in sequence an additional 90-degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
Good luck with this job!
Feb 06, 2011 | 1998 Mazda Pickup
Request the cylinder head torque for a Yanmar 6HAL DTN generator engine
I hope this helps.
Jan 25, 2011 | Computers & Internet
NEED HELP WITH TORQUE SPECS ON 1998 CHEVROLET SURBURBAN CYLINDER HEADS 5.7
Cylinder Head Removal & Installation 5.7L Engine To Remove:
  1. Disconnect the negative battery cable.
  2. Drain the engine coolant.
  3. Remove the air cleaner assembly.
  4. Remove the upper radiator hose.
  5. Remove both heater hoses.
  6. Disconnect spark plug wires at distributor cap.
  7. Remove distributor cap.
  8. Remove the coolant bypass hose from the water pump.
  9. Remove the drive belt. NOTE: It is not necessary to evacuate the A/C refrigerant.
  10. Remove the A/C compressor from the mounting bracket and set it aside.
  11. Remove the wiring bracket from the rear of the cylinder head.
  12. Disconnect the accessory bracket and slide forward.
  13. Remove the upper and lower intake manifold.
  14. Remove the exhaust manifolds.
  15. Remove the valve rocker arms and pushrods.
  16. Remove the power steering pump pulley.
  17. Disconnect the electrical connector from the power steering pump.
  18. Remove nuts attaching the power steering pump to the engine.
  19. Remove power steering pump mounting bracket bolts and nut.
  20. Slide power steering pump/bracket assembly forward and remove stud.
  21. Set power steering pump/bracket assembly aside.
  22. Disconnect the wiring bracket from rear of the right cylinder head.
  23. Remove the generator.
  24. Remove the oil indicator tube bracket bolt.
  25. Remove the generator mounting bracket.
  26. Remove the sixteen cylinder head bolts.
  27. Remove cylinder heads and gaskets.
  28. Clean all sealing surfaces.
To Install:
Right Side NOTE: Clean all dirt, debris, and coolant from the engine block cylinder head bolt holes. Failure to remove all foreign material may result in damaged threads, improperly tightened fasteners or damage to components.
NOTE: Do not use any type of sealant on the cylinder head gasket (unless specified).
  1. Clean the cylinder head bolt holes with a thread chaser and compressed air.
  2. Check the cylinder head locating pins for proper installation.
  3. Place a new cylinder head gasket over the engine block dowel pins.
  4. Install the cylinder head to the engine block.
  5. Apply sealant (GM P/N 12346004 or equivalent) to cylinder head bolt threads.
  7. Tighten the cylinder head bolts in sequence on the first pass.
    • Torque to: 22 ft. lbs. (30 Nm)
  8. Using a torque angle meter, tighten the long bolts (1, 2, 5, 6, 9, 10 and 13) on the second pass in sequence to 75°.
  9. Using a torque angle meter, tighten the medium bolts (14 and 17) on the second pass in sequence to 65°.
  10. Using a torque angle meter, tighten the short bolts (3, 4, 7, 8, 11, 12, 15 and 16) on the second pass in sequence to 55°.
  11. Install the valve rocker arms and pushrods.
  12. Install the generator mounting bracket stud.
    • Torque to: 15 ft. lbs. (20 Nm)
  13. Loosely assemble the generator mounting bracket over the stud.
  14. Install all nuts and bolts finger tight.
    • Torque to: 30 ft. lbs. (41 Nm)
  15. Install the generator.
  16. Install the oil indicator tube bracket bolt.
  17. Install the exhaust manifold.
  18. Install the lower intake manifold.
  19. Install the valve rocker arm covers.
  20. Install the wiring bracket to the rear of the cylinder head.
  21. Connect the accessory bracket.
  22. Install the A/C compressor.
  23. Install the drive belt.
  24. Install the distributor cap.
  25. Connect the spark plug wires to the distributor cap.
  26. Install both heater hoses.
  27. Install the upper radiator hose.
  28. Install the air cleaner assembly.
  29. Refill the engine coolant.
  30. Connect the negative battery cable.
Left Side To Install:
  12. Install the power steering pump mounting bracket stud.
  13. Loosely assemble the mounting bracket over the stud.
  15. Install the power steering pump pulley.
  16. Connect the electrical connector to the power steering pump.
Aug 31, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
