Question about Worx WG788 19Inch 36 Volt Cordless 3In1 Lawn Mower With Removable Batter
It only runs for a few minutes then stops the battery has all green lights
This is happening to min did u figure out what's ronge
Posted on Aug 07, 2015
Battery light on lightly
Check the alternator belt tension it ok . Then With the engine running at a fast idle check the voltage at the battery terminals , 14 to 15 volts ok . 12 volts or below the alternator or voltage regulator is at fault.
Sep 22, 2014 | Cars & Trucks
Green light flashes when i stop for a few minutes
Hi, okay but does the scooter still run okay ? if so, it maybe warning you that the batteries are getting low, sometimes the voltage detection circuit can get sensitive or simply faulty.
Regards
Rob
www.gewizrepairs.co.uk
Dec 31, 2013 | Lynx L-4 Motorized Scooter
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
Blinking lights
The problem is, is that while the unit is not overloaded (too much plugged in) either the batteries are close to failure, OR more likely you have so much plugged in you have less than 2 minutes of runtime.
Try removing some devices, lower the load. The row of green lights on the left is your load level indication, you want no more than 4 lit usually, 80% load is the most recommended. This will allow more runtime and should stop the flashing.
The flashing is just ment to alert you to less than two minutes of runtime.
If you have 80% load or less, and it still flashes, press and hold the on/test button until it clicks over to battery, the unit will now run a self test and switch back to main power after a few seconds and it should stop blinking.
If you want a copy of your user manual, you can find it here: http://www.refurbups.com/KB-M-Smartups (the Smart-UPS 1000)
Apr 08, 2010 | APC Smart-UPS 1000VA UPS System
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
The laptop powers itself down after only a few minutes of operation. the charger seems to be working and both power and battery lights will show green the laptop is old and i am wondering does it have to...
good or bad. it needsa battery to tun If good then it runs on its own and if bad then support of the charger is required. Can run without the battery too if the charger is present.
Jul 14, 2009 | Computers & Internet
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Worx WG788 19Inch 36 Volt Cordless 3In1 Lawn Mower With Removable Batter Logo
200 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
