Question about Garden
Ariens 5520 snowthrower only runs if i rapidly push primer button
  • 113 Answers
Check for cracked fuel line.
Could be sucking air in with fuel starving engine of fuel.
Does float in carb operate correctly?
Float maybe full of fuel.
Posted on May 08, 2014
  • 109 Answers
SOURCE: Mower will not stay running unless primer button
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Posted on Apr 16, 2009
al_kupchella
  • 843 Answers
SOURCE: KEEP GOING ONLY IF YOU KEEP PUSHING THE PRIMER BUTTON
You have a clog in the gas flowing into the carburetor. Get some carb cleaner (the spray kind is fine). Drain or siphon the gas out of your mower and discard. Put a little fresh gas and a little carb cleaner in the tank. Run it through. Do this a few times if necessary. When you get new gas, add a gas stabilizer like Sea Foam.
Posted on May 05, 2010
SOURCE: My Ariens lawn mower dose not get gas to the Carb
You have gas in the float bowl but nothing coming out when you prime correct?
You should remove the bowl jet *(should actually be the bolt that holds on the bowl) and wire brush it clean and then run a fine piece of wire strand through the jets. One of those openings is very tiny.
It is located at the top of the threads and you will need a tiny piece of wire strand to clear this. When you have cleared this and the two bigger openings at the bottom of the bolt put it back in and see if she primes. The primer just puts a raises the air pressure inside the bowl so fuel flows up the main jet. So a blocked main jet will prevent priming and running at anything above idle speed.
Good luck and be careful!
Posted on Jul 23, 2010
SOURCE: I have a Yard Machine snowthrower that starts then
you need to remove the carb from the engine, tear down(don't worry they don't have many parts inside) and soak and then use carb cleaner or compressed air to blow out the ports insind the carb. this should solve your problem.
Posted on Nov 27, 2010
  • 6468 Answers
SOURCE: red primer button stuck pushed in on 550 series mower
sounds like the pasagges are plugged up
Posted on Apr 01, 2012
Snowthrower will only keep running if primer is pushed
sounds to me your main jet in carburettor is blocked .have carburettor jet cleaned this will solve your problem .
Feb 14, 2014 | Garden
Gas leaking from carburetor bowl drain screw when pushing in primer. Push primer two times and couple drops of gas on floor. Any way to tighten spring screw on carburetor bowl?
Sounds like you need a gasket on that screw. Don't over tighten as you could mess up the threads. I think this is the screw that has the
fuel jet in it. If you take it out its good to clean out that jet as well to have a good running machine.
Jan 05, 2014 | Mtd Snowthrower 208cc 26"
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Model A173K22 Primer Where?
What? !O_O!
Oh,.....................I was going to say, I don't remember any laptops coming with a priming feature, lol!
In answer to your question there is no priming feature, for an Ariens walk behind gas lawnmower, model A173K22,
Page 9,
http://www.managemylife.com/mmh/owner_manuals/134166/ARIENS-Walk-Behind-Lawnmower-Gas-1011731L
Regards,
joecoolvette
Aug 28, 2012 | Computers & Internet
I have an Ariens 624E, it seems I forget the proper sequence to start the machine. COuld someone guide me through it please
turn the choke all the way to the right (dial on side of engine) hit the primer button a few times (right in front of you red button squishy and pushes in) pull start it and it will start right up. Or it does have push to start instead of pullin it
Jan 11, 2011 | Ariens Garden
I have a Yard Machine snowthrower that starts then shuts down in a few seconds. I can keep it running if I push the primer button when it starts to die...any suggestions? I have: drained fuel and put in...
Nov 27, 2010 | Garden
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
