Question about Bosch 24 in. SHU68 Built-in Dishwasher
Timer stuck on 10 and other issues
Running our Bosch dishwasher SHU6805UC on "quick wash" the timer counts down to "10" and then stays there forever and we have to cancel the cycle.  Any ideas??
We also seem to have a leak when the dishwasher is just sitting there I am attributing this to the timer not completing the cycle and water finds a way to leak out.  Or it could be that the inlet valve is letting water and the dishwasher fills to the point that it can leak out??
4 Suggested Answers
SOURCE: My Bosch dishwasher won't shut off. The timer says
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Posted on May 03, 2009
DrakeTech
  • 61 Answers
SOURCE: I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Posted on Dec 30, 2009
localwonder
  • 6784 Answers
SOURCE: My Bosch SHU66C is not filling with water. Timer
HI. First you will need to make sure you are getting water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you are receiving water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case the valve should be inspected and replaced, if needed. Us the procedure below to guide you through the inspection process.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
Posted on Apr 07, 2010
Not water comes into Bosch dishwasher?
Assuming you have verified water is actually getting to water valve, most likely water valve is the problem and needs replacing.
Sep 10, 2017 | Bosch Washing Machines
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
Bosch SHU 3032 dishwasher gets stuck halfway through the wash cycle and just continues to wash until you manually advance it. I turned in on before bed one night and it was still running the next morning....
It obviously sounds like a timer issue here, and as it's embedded in a big chip on the control board, I would think a new control board is needed.
The exception to this is if it is not heating at all, in which case it won't advance if the water is not hot enough. Try it again and see if it gets warm.
If not - replace the heating element.
Most machines just stop to heat up the water, but to cut down cycle time they may recirculate the wash-water first to speed things up.
May 04, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Timer (cycle knob) gets stuck on occaision and
possible that its the timer more likely an internal blockage main wash water level not being reached and activating heater if the water does not reach temp selected for any reason the appliance will stick at the heating phase also if your dishwasher is getting old over 10 years wiring loom in door may be breaking down, will need service to sort out
Nov 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer keeps spinning water and not moving on to the next cycle
Sounds like the timer has gone bad and is not letting anything work. Washers, dryers and dishwashers have a timer that you set at the start and then the system counts down off of that. If that stops working it will run forever
Feb 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwahser rinse cycle running for hours
Do you have high temp rinse or sanitize selected? This will pause the timer during the final rinse cycle to heat the water. The sensor might be bad. Try the quick cycle, I don't think this heats the water.
Jun 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Sensotronic dishwasher will not drain
I think I may have figured out a work around (by accident).  Start a cycle (any cycle), once it starts hold down Scrub Wash and Delicate/Economy at the same time for 3 seconds and the cycle will immediately finish (counting down quickly then to CL) and it will begin to drain.  I had to do this 3 times(draining more each time) but the end result was a completely empty bottom of the Dishwasher. To be honest I think this is the first time the thing has ever been completely empty!  I wish I was joking...
Garth
Nov 05, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU68 Built-in Dishwasher Logo
64 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
