Question about AmeriHome Ice Cream Maker
Gear in motor on ice cream maker striped out - AmeriHome Ice Cream Maker
Motor will run but the buckle will stop turning when you add ice
That usually means that the gears in the unit need to be repaired. This might be able to help.
White Mountain Ice Cream Freezer Motor Repair
Sep 09, 2013 | White Mountain F69206X 6 Quart Ice Cream...
White Mountain 69204 ice cream motor gear slips
Sometimes the gears in the unit become worn and have to be replaced. This might help.
Sep 04, 2013 | White Mountain F69206X 6 Quart Ice Cream...
My motor runs but doesn't turn the ice cream container. This is before I put in any ice or salt. It starts to turn then stops.
The gears are bad inside the gearbox...
Hereis a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Apr 01, 2011 | White Mountain F69206X 6 Quart Ice Cream...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
Welcome to FixYa
An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
Read Following ...
  • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
  • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
  • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
  • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
  • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
OR click here
Just Check this Link too
Thanks for Contacting FixYa...
Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
Rival icecream maker
Perhaps some gears are breaking inside the motor? If you need parts, they are sometimes available here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=rival+ice+cream&submit=Search&_sid=93311479
May 27, 2010 | Rival 8401-M 4 Quart Ice Cream Maker
OUr rival 8550-x 5 quart wooden electric ice cream maker doesn't turn the blade in the canister. The motor is running but the blade doesn't turn in the canister.
take it apart and find the striped gear the motor actualy turns at 2000 rpm and has a reduction unint inside
eithor the gear is striped or the grub screw fell out of the drive gear could also be a drift or sheer pin on the main shaft
Aug 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
AmeriHome Ice Cream Maker Logo
Top AmeriHome Ice Cream Makers Experts
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you an AmeriHome Ice Cream Maker Expert? Answer questions, earn points and help others
