Question about Sharp Aquos LC-37D90U Television
Where can i buy a lvds cable for sharp aquos LC37D90U TV
  • 4234 Answers
SOURCE: analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Posted on Aug 23, 2009
satavlad
  • 405 Answers
SOURCE: Is there a headphone jack on the sharp aquos 46?
There is no headphone jack on this TV
Posted on Dec 05, 2009
Why is my 2011 Sharp Aquos TV crashing?
Sharp Aquos "crashing" - HDTV - Streaming Video & TVs - Tom's Guide
www.tomsguide.com/forum/24705-4-sharp-aquos-crashing
Aug 11, 2005 - 7 posts - ‎1 author Archived from groups: alt.tv.tech.hdtv (More info?) I have a Sharp Aquos 37" LCD TV(37GD6U). Every now and then I can turn it on,
Oct 20, 2015 | Sharp Televison & Video
Blue areas screen
Sounds like T'Con fault. Check the connection to LCD panel from T'Con for any loose contact. Reseat this cable, [the flat cable goes to LCD panel from the T"Con board; LVDS cable] once and check. Gopakumar Gopalan Google
Apr 19, 2014 | Sharp Televison & Video
Sharp aquos horizontal streaks
A loose contact at the sockets to LVDS cable, that connects its T'Con board to display panel will show this kind of fault on screen. Check it. If you wish to get more details about it, check the link sited here. http://electronicshelponline.blogspot.com/ It has illustrations and descriptions about the faults that occur to LCD TVs. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No picture -- white screen -- no sound
With no video and the the colored stripes, it sounds like the LVDS cable needs to be reconnected to the LCD control board or the control board itself is bad. If the unit is only 3-4 months old, it should be covered by warranty
Nov 18, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52 SHARP AQUOS
Either bad connection with the LVDS cable, defective LCD controller, or even a defective LCD panel. Can you post pictures?
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37D90U Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
