Question about Mr. Coffee DRX23
Mr. Coffee DRX23 stopped brewing in the middle of a pot
Burner also not working. LED display is fine. Is there a fuse in there I can replace? If not, what could have died?
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: mr coffee 072179228578 won't brew
There is a thermal fuse of poor quality in every one of these machines to protect against fire.
If you are unlucky, it fails early and at a safe temperature, if you aren't it may hold forever.
Two years ago, I had three coffeemakers fail in two days; I got a refund instead of a fourth.
Because the parts are spot-welded together, these machines are essentially unrepairable.
If you want to peer inside, look for a cylindrical part about 5/8 " long with one pointed end; this is the thermal fuse.
DON'T consider bypassing it, I know of one counter that caught fire after the thermal switch that controls the heater got stuck.
Posted on Jul 18, 2008
  • 1214 Answers
SOURCE: Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Posted on Jan 30, 2009
cactus bob
  • 267 Answers
SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Posted on Mar 01, 2009
  • 186 Answers
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Posted on Nov 05, 2009
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
Just made my first pot of coffee in the 5 cup Mr. Coffee maker. The coffee is brewing off to the side instead of in the middle. What did I do wrong?
Make sure you have the right filter in it . They make several and some makers have only certain ones that can be used with their product . Good Luck !
May 31, 2017 | Mr. Coffee Coffee Makers & Espresso...
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
The burner quit working. can I fix it or is it trash
  1. Many grocers and retailers that carry Mr. Coffee® Iced Tea Makers, carry Mr. Coffee® replacement items. Try the retail location where you purchased the unit.
  2. If not, Call 1-800-MRCOFFEE (672-63333)
Jan 14, 2011 | Mr. Coffee DRX23
Mr. Coffee 12 cup Isx43cp will not brew coffee. I push the brew now button and it beeps 5 times as if it has just finished a pot.
I had the same problem and fixed it. I took the bottom off. There is two hoses there which one has a (valve)plastic thing with little ball in it. I took the hoses off and the valve out of the hoses. I then cleaned the hoses,valve and the pipe arround the burner. There was like hard white dirt in them. I put back on the hoses without the valve. Tried to make coffee and it worked but was noisy . I ran it like that for a few days and still worked but noisy. I then took hose off and put back in valve. Then tried it again. It still worked but now it is quiet. Clean parts,hoses,valve,and pipe near burner good. Worked for me. Good Luck on yours.
Oct 06, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
My mr coffee pot will not stop brewing when I pour a cup of coffee while it is still brewing. My model has the brew/pause feature
There may be grounds stuck in the spring loaded gadget next to the pot's pour spout - Remove all interior parts and rinse under water.
Sep 29, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Model DRX23
if machine work fine led screen is going it a maner of time before you see nothing cheers
Jan 23, 2008 | Mr. Coffee TFTX85 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
