Question about Toshiba Satellite A205-S4617 Notebook
Toshiba a205 s7466 will not turn on replaced cmos battery what next?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Check ram and power button
Posted on Apr 29, 2014
4 Suggested Answers
  • 2976 Answers
SOURCE: Toshiba A205-S4577
Check your power settings. You might have it set to shut off after a certain time of non-use.
Posted on Jan 16, 2009
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
  • 10406 Answers
SOURCE: how do i clear cmos
Start your computer, and enter BIOS SETUP.
Select "Load BIOS Defaults".
Save & Exit from BIOS SETUP.
Posted on Aug 29, 2010
use old battery first try to boot
if your system is boot run bios update from intel.com
then change new battery
else run bios flash from chip level service provider
Feb 14, 2014 | Toshiba Satellite A205-S4617 Notebook
Computer will not power up
You can detach the main battery, and leave it for a week. If next week your laptop still has the same problem, then it means your laptop is dead.
Toshiba satellite a205 will not turn on is it the power supply regulator on top rear panel?
Check AC power cord, use a different one, also plug into different outlet. If that doesn't work power switch is bad. Or something else is wrong.
Feb 13, 2014 | Toshiba Satellite A205-S4617 Notebook
Where is the cmos battery on satellite a205-s5308
What were the Toshiba Engineers thinking. Take a look at the :http://www.ehow.com/how_5136793_replace-cmos-toshiba-satellite-laptop.html
Dec 17, 2012 | Toshiba Satellite A205-S5803 Notebook
How to remove CMOS battery for A215-S7444? I done a search and got this answer: "This should help: * Remove Laptop Battery * Remove Memory Cover * Spread spring clips to outside and * pull out RAM...
What are you trying to do? Replace the CMOS battery, or reset a BIOS password?
This is what the CMOS battery looks like,
http://www.ebay.com/itm/CMOS-RTC-Battery-Toshiba-Satellite-A210-A215-Series-/270970735656?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D160437620636%26ps%3D63%26clkid%3D8748715535548215160
Now view this pictorial disassembly guide,
Page 1 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Page 3 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
Go to the photo in Step 17, and click on it to enlarge.
See the CMOS battery in the middle/left?
Round silvery looking object. Go straight down from the red arrow to the far left.
That is how to access the CMOS battery.
(Yes I know it states Satellite A200/A205. Same for the A215)
Now BIOS password reset?
Do not know where the two copper pads are to briefly short out. Suspect under the Ram Memory modules, (And under a small sheet of Mylar plastic), or under the Wireless Modem. (And under a small sheet of Mylar plastic)
The links on this solution I gave may help,
http://www.fixya.com/support/t6645137-toshiba_l500_clear_cmos
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Am I concerned that you may have stolen the laptop, or are trying to break into someone else's laptop?
NO
Your real name, and IP address are recorded on FixYa, to give to the authorities, if needed.
I figure a thief would not risk this ]
May 28, 2012 | Toshiba Satellite A215-S7444 Notebook
Replace cmos battery
Wow that's a bummer if it is soldered to the motherboard. Sounds like you will have to desolder the old one and resolder a new one. Good Luck
Mar 19, 2012 | Toshiba Satellite A205-S5814 Notebook
My toshiba laptop is askingn for a password to turn on. I know this relates to the cmos battery. I have the toshiba satellite A215-S7413, how to i get to the cmos battery?
How to get to the CMOS battery
The Toshiba Satellite A215-S4747 Notebook PC's CMOS battery, is soldered to a bracket on the bottom of the motherboard.
The laptop has to be completely disassembled to access it.
In this photo showing the bottom of the motherboard, the CMOS battery is in the middle,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-21.jpg
This is a link to a free Service Manual, detailing disassembly,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the 11th line down. The one that starts with Satellite A10
Go across and click on A215
This is a PDF file. It may take up to 30 seconds before you see the first page, and additional time to fully download.
Suggest you let the file download all the way before looking through it.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
Suggest you bu and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
Average price is around $3 to $6.
3) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
There may be as many as 60 screws and 12 different types.
Do Not mix them up.
(You can use a clean egg carton in a pinch. Mark each egg holder)
Nov 26, 2010 | Toshiba Satellite A215-S4747 Notebook
My toshiba a205 s5804 is asking me a bios password
remove ac supply and battery from the laptop.. and press power button for atleast 30 sec.. it reset the CMOS memory.. this is what toshiba technical support person told me to do when i called to them way back..
Nov 04, 2009 | Toshiba Satellite A215-S4747 Notebook
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
