Question about Panasonic PT-60LCX64 Television
Panasonic PT-60LCX64 is having sound issues. The speakers work, but after a short time, there is a crackling sound and the left side stops working. Don't know if it's the main board or the smaller amp board in the speaker housing. I am assuming it's the main board due to the heat. Where can I buy the replacement boards? Any help would be greatly appreciated.
TVtechmaniac
  • 140 Answers
SOURCE: Replacing STK392-110 IC Panasonic PT-51HX41 51 in. Rear Projection Television?
Just put something under the connector (like a screwdriver)and lift up....they are very sturdy and I have never had one break for me.
Posted on Oct 06, 2007
SOURCE: my panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Posted on Jan 04, 2008
battlesmith
  • 382 Answers
SOURCE: Panasonic PT-47WX53G Convergence Problem - board replaced still does not align
hi,
First start by verifying your TV is plugged directly
into a wall plug, no extention cords and no surge protectors.If plugging into the wall stops the shutdowns then
go out and replace what ever cord you were using.otherwise you need a TV tech to look at the TV,the problem could be in many places in the TV where convergence IC may be failing
135 volt supply to the horizontal sweep could be low
almost any low voltage supply could have a cracked
solder connection causing random interuption,also I recall nuisence shutdowns with that Model from the CPU PCB being loose.Left side of chassis all the way to front of PCB
its a small PCB that docks into signal main PCB
and it has 3 plugs that fit into sockets and it does
get loose over time (heating and cooling).What I would do would be unplug the TV then remove and remount the CPU PCB..Thank you!!..
Posted on Jul 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Posted on Aug 13, 2008
  • 449 Answers
SOURCE: slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Posted on Mar 03, 2009
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Problem with Panasonic PT-60LCX64 Television My tv which is a PT-60LCX64 will not turn on. It blink green several times and will not show a picture then it turn red blinking light.I tried unplugging and...
Sounds like an internal power issue. Usually a red blinking light is a fatal error, such as bulb or capacitor.
Follow this link and scroll to page 100 to begin the troubleshooting steps.
http://service.us.panasonic.com/OPERMANPDF/PT43LCX64.PDF
You will need adobe reader.
Adobe Adobe Reader free PDF viewer download
Apr 10, 2014 | Panasonic PT-60LCX64 Television
My Panasonic PT-60LCX64 television keeps having a problem with temperature. Every few hours, the TV will turn off and the temp light will blink 4 times. It will turn back on if we give it a rest of 10
Sounds like a fan issue which is possiblt slowing down as it gets warm. I would try removing the rear cover and set a fan behind it blowing on the chassis and see if the set keeps running if so the fans would be suspect.
Oct 14, 2012 | Panasonic PT-60LCX64 Television
PT-60LCX64 no sound
check to make sure speakers in the menu are not switched to OFF. and inside set look to see speakers are plugged into a board somewhere.
May 31, 2012 | Panasonic PT-60LCX64 Television
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
How do i access the lamp on a panasonic pt-60lcx64?
Pull the front panel off and you will see a srew on the left side. Remove that screw and a smaller cover will come off. Then remove the srew that behind the small cover and then you can pull the lamp assembly out.
Aug 14, 2009 | Panasonic PT-60LCX64 Television
TV is not working anyore
maybe stupid but try to plug-unplog from power outlet.. does it make any sound? kliking sound? if nothing helps than your starter is gone.
Apr 28, 2009 | Panasonic PT-60LCX64 Television
External speakers
Unfortunately no. The Panasonic PT-60LCX64 TV does not have any jacks, plugs or external connection point to attach he wires of external speakers.
Alternately however, it is possible to install 2 pairs of speaker terminals on the backboard and wire them in parallel to the internal speakers.
Hope this be of help/information. Good luck and kind regards.
Feb 05, 2008 | Panasonic PT-60LCX64 Television
Panasonic PT-60LCX64 Television Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
