Question about JVC XL-R5000BK CD Player
Record tray keeps ejecting - JVC XL-R5000BK CD Player
Samsumg bluray e6500 keep ejecting
Reduce any lights or reflections that can be detected by the "remote eye" on the player. Increase the distance to other electrical equipment.
Mar 30, 2014 | Samsung BD-E6500 3D BluRay Player No...
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
Multi dvd recorder+vcr (LG0 KEEPS REJECTING DISC TRAY
The remote control eject button has been applied pressure. Observe the eject button on remote to dislodge any stuck keys.
Feb 03, 2011 | LG Computers & Internet
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
A jammed DVD will not eject. Message"Repairing" goes on and on and nothing happens.How can I reject the dvd?
To whom it may concern
Thank you for the offer. I will bear it in mind should I need further assistance.
I solved the problem by removing the cover and loosen the clips where the disc tray is and slid the release tray and by pressing the eject button, the tray ejected the disc.
I have tried other discs by recording, deleting and ejecting and so far the problem has not been experienced again.
Kind regards.
Mr. NTD
Jan 11, 2010 | Funai PY90DG DVD Recorder
Disc won't eject & stops working
your disc tray is jamming on an intermittent fault and when it does work it is recording each time the eject botton is being pressed so when your watching movies or playing games it tries to eject the disc tray and causes an automatic shutdown it will definately neet proffesionally repaired and should cost about 30-40 pounds and get a guarantee with it bacause these faults can come back to haunt you.
Oct 06, 2008 | Microsoft Xbox 360 Console
Un-lock dvd region code
Power up the unit with no cd/dvd on the tray
Press "eject" on your remote to eject the tray
Press "setup" on your remote
Key in "5018" using your remote
Key in "0"
Press "play" on your remote
Tada~ a region free dvd recorder
Tried this but unfortunately the machine keeps reverting back to Region 4.
Has a step been left out or is there some other way of changing the code to "0".
Jun 14, 2008 | Televison & Video
Keeps ejecting dvd
Does it also do this without a DVD in the drawer? Does the drawer open even when it's empty or only when it has a DVD on the tray?
Allen
Jun 04, 2008 | RCA DRC8320 DVD Recorder/VCR
"safe" keeps me from opening dvd tray manually (must use remote control)
I unplugged the recorder for 10 seconds, replugged it in and voila, the problem was solved.
Walt in Indiana
Apr 11, 2008 | GoVideo VR3845 DVD Recorder/VCR
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
JVC XL-R5000BK CD Player Logo
32 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
