Question about Ecoquest Fresh Air Air Purifier
My ecoquest air purifier says replace plate - Ecoquest Fresh Air Air Purifier
Cerfer39
  • 709 Answers
SOURCE: replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Posted on Sep 26, 2007
SOURCE: ecoquest air purifier uv lamp replacement
Changed my purification plate and when I started the unit back up it just would start the fan and then shut down in about 7 seconds. It will restart the same process, but will not stay running. The fuse looks good, and it is making the filter switch can anyone suggest the next idea
Posted on Dec 22, 2007
SOURCE: Living Air Purifier (Flair Model) Ecoquest
Pull the unit out of the box and flip it upside down. You should see it
Posted on Mar 16, 2008
SOURCE: EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Posted on Aug 10, 2008
Dutch7773
  • 31 Answers
SOURCE: Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Dutch
Posted on Mar 05, 2009
What can I do for two Ecoquest fresh air 2.1 that both flicker on start up?
It doesn't sound fixable in the field. It may be a control panel issue. Contact Vollara (which bought Ecoquest) & get through to tech support. 800-989-2299.
Apr 27, 2014 | Ecoquest Fresh Air Air Purifier
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Jun 14, 2012 | Ecoquest Fresh Air Air Purifier
Where can I find wiring diagram for Ecoquest air purifier. Replaced UV lamp and disconnected wires and cannot remember how to place them.
Try checking the contacts to the ozone plate. Or a wire may be loose--check the contacts and sometimes they need to be cleaned with alcohol.
Apr 19, 2012 | Ecoquest Fresh Air Air Purifier
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
Why do you have to replace the plates in Ecoquest Fresh Air Unit
They get filled with the **** in the air which they remove for you.
Apr 16, 2009 | Ecoquest Fresh Air Air Purifier
I have a Fresh Air Unit from Ecoquest. The
When that message appears the plate does not make good contact with the two contact points. You can use rubbing alcohol and a q-tip to clean the points. After 1-2 years it is also advisable to change the purifier plate. Plates are about $15 and can be purchased at EcoQuest.com
If the plate is dirty (and this can unnoticeable grime-grease) clean the plate with 1 part clear ammonia and 1 part water. An old tooth brush works great.
Dutch
Ecoquest fresh air repair
Regardless of unit the purifier plates may need replacement. How are the plates cleaned? Could it be that there is a residue from the cleaning agent present after cleaning? With new plates there is a little oil on the plates to prevent oxidation when in storage or transit. A little rubbing alcohol would do the trick.
Make sure the plates are dry before putting them back into the unit.
If the plates are seated right and clean you should see a faint purple glow on the plates when the unit is on purify.
Let me know if that's the case.
Eric
Dec 18, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
46 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
