Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Temp light flashes and tv does not come on - Hitachi UltraVision CineForm 55VG825 55" HDTV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Standby/temp light and Lamp light are flashing
Sounds like a samsung but I will need the model number to assist you more accurately. Please respond to this same post.
Dec 04, 2009 | Televison & Video
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
LAMP LIGHT ON AND TEMP LIGHT, TELE WILL NOT COMME BACK ON
Look in the owner's manual. These lights indicate the current condition. Usually the lamp light will go on if the lamp has failed and similarly the temp light if the fan has failed. With both, there may be a different problem. If you can confirm your model number, I can look up the problem indication as well.
Thanks,
Dan
Aug 25, 2009 | Hitachi P50S602 50 in. Plasma TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
13 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
