Question about Samsung Audio Players & Recorders
How to setup wireless headphones on my samsung 46 inch 3 d smart tv
The wireless headphones are sennheiser RS 120
SOURCE: Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Posted on Mar 08, 2008
  • 155 Answers
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Posted on Jul 07, 2009
SOURCE: Hello, I am looking for the Sennheiser Wireless
Sennheiser sent me the manual.
Thank you, Eletta
Posted on Aug 17, 2009
Grubhead
  • 5259 Answers
SOURCE: I need replacement ear cushions
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Posted on Feb 19, 2011
Do sennheiser tr120 wireless headphone rechargeable batteries ever need changing
Yes All batteries are subject to failure and eventually need to be replaced, some last longer than others it's a manufacturing consistency problem. ...
Feb 27, 2015 | Sennheiser RS 120 Consumer Headphones
Works with Direct TV but will not work with Net Flexs. I have a Sansung 2010 smart TV with Samsung sound bar
If it works with one, it would work with both unless you have it hooked up wrong or are not using the proper settings.
Jul 13, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
No audio just static
Surely the instructions for your new Samsung TV provide at least minimal information regarding what does what.
Dec 21, 2013 | Sennheiser RS 120 Consumer Headphones
We have purchased sennheiser RS 120 wireless headphones but find our LG tv model 32LS3450 - TA does not have audio out, is there a solution?
Your TV should have Audio out somewhere, even if its digital audio out, you could output to a receiver and then hook your headphones to the receiver.
Oct 13, 2013 | Sennheiser RS 120 Consumer Headphones
THE HEADPHONES ARE CHARGED BUT WONT WORK. THERE IS A CONTIOUSE GREEN LIGHT WHICH IS ON. ON THE HEADPHONES.
Wireless? Are they connecting with the base? Try unplugging the base to reconnect. What are they connecting to? TV? computer? What?
Nov 10, 2012 | Sennheiser RS 120 Consumer Headphones
I have a new Samsung TV (LED 6000 series). I can not get my Sennheiser RS 120 to connect. I have plugged them into the audio out jacks at the back of the TV. They always worked perfectly with my old...
There is a possibility that internal speakers have to be turned off to direct audio output to the rear connector. You can confirm this by going to the initial set up procedure to disable internal speakers.
Jan 10, 2018 | Sennheiser RS 120 Consumer Headphones
Audio from tv is not restored by turning off power on headphones
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
