Pitney Bowes U560 Won't turn on message says "cover open"
Bubbabear64
  • 2794 Answers
SOURCE: Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Posted on Jul 11, 2008
SOURCE: Pitney Bowes Copier - C180 - Error E3
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Posted on Sep 17, 2008
SOURCE: I am looking for a service manual for a Pitney Bowes FD40
http://www.pitneybowestsg.com/public/Opguides/Fd40u036.pdf
Posted on Mar 20, 2009
WhiteDracos
  • 8 Answers
SOURCE: Ink cartridge installed backwards
use a non magnetized screwdriver and take the top cover off then unscrew the screws holding the guide bar in and gently pull the ink cartrige out you may reuse the cartrige but not recommended.
Posted on May 26, 2009
SOURCE: I am looking for a driver download:Pitney Bowes DA300 for Vista
Yes they do.
Here you go: http://www.pitneybowestsg.com/public/prod_da300.html
Posted on May 29, 2009
Pitney Bowes FD40 error top cover open
Locate the top cover switch that is apparent stuck in the open position. Fix or bypass it.
Oct 20, 2016 | Pitney Bowes Office Equipment & Supplies
I have a Pitney Bowes Model 1630 copier / printer, Message "Printer Jam offline" .No Paper jamed in unit...How can I fix ?
A sensor is probably blocked or a torn piece that cannot be seen is in there. Take a can of air to it. Also turn it off and turn it back on for added measure.
Mar 09, 2011 | Pitney Bowes Office Equipment & Supplies
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Pitney bowse every time show this messages
We need your model number.
Also check your toner cartridge carefully. A toner that is not fully locked in can cause this error.
Oct 30, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
Pitney bowes 1225 letter opener
I don't know if Pitney Bowes is still servicing those anymore but you can find out on their website:
www.pb.com
Select the customer support section.
Nov 21, 2008 | Office Equipment & Supplies
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
26 people viewed this question
jasbo
jasbo
