Wac700 the LCD light is keep on flashing and says HW test result 000000
Phillips wac700 says booting up has not been used for a while
Hello
Just unplug the device from AC mains socket and replug it after 3 minutes and see whether it helps you. If not, a firware upgrade will be necessary. The supplied PC installer CD contains Media Manager [DMM] software. it will help you to upgrade for WAC700 center. For details see DMMs' help file. Refer to the manual CONNECT YOUR PC to learn how to install the software. OK.
Jan 16, 2012 | Philips WACS700 Shelf System
Dell xps 400 continues to randomly sod and reboot even after full reinstall. Scanned for malware, replaced hard drive, tested all hw components with Dell diagnostic utility. Thought it was powersupply...
Hello.
If you did all of the above, the only other components are memory or motherboard issue. Couldn't be malware if you reinstalled the operating system.
Something is causing it to overheat. Try removing the memory and test each module at a time, first.
Hope this helps.
Oct 09, 2010 | Dell XPS 400 PC Desktop
Same problem, i downgraded it to XP. Now i cant get any sound. It says ''no sound device installed''. base devices have yellow warning signs on it... what do i do? pls help? ------------------ System...
Hi
Thank you for your query
Please try the following
1) Go to www.devicedoctor.com and download and install the software
2) Load up the program and then click on 'begin scan'
3) This will scan and hopefully pick up the missing drivers for your sound
4) Click on download for the sound drivers
5) Install the drivers and enjoy
I hope this has been useful
Mar 16, 2010 | Toshiba Satellite A305D-S6835 Notebook
My adapter light comes on but the battery light keeps flashing then goes off and the laptop wont switch on i have an acer aspire 5735.
The computer has a problem, even without the battery you should still be able to run the computer on the power supply.
Consult Acer support on hw to get it fixed.
Mar 07, 2010 | Acer Aspire 5735 Notebook
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
99 people viewed this question
 Grubhead
Grubhead
