Question about Zanussi TD4112W Electric Dryer
It doesnt seem to dry very well or takes a really long time
    New Friend:
Zannusi Dryer TDS383W element gets Hot (glows)then cuts out after few seconds then if I wait for couple minutes and reset the clock to any set time the element glows hot again until inbuilt thermostats 'click' again cutting out the element,this process is continuous with or without the lid and ducting in place.
Posted on Oct 19, 2015
Motorcycle complete loss of power and bike dies
check that the tank cap is venting and not causing a vacuum in the tank and lack of fuel to the engine.
Jun 01, 2013 | Motorcycles
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
It is drying okay on high but when i use the low setting it is taking 3 times as long to dry. I can hear the heat turn on minutes after starting the dryer but it doesnt seem to be staying on
i would say a venting problem here is a website that may or may not help Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
Oct 24, 2010 | Dryers
Dryer wgd5300, takes a long time to dry. seems
The burner is supposed to05245ec.jpg cycle on and off all through the drying cycle. Over time the operator coils 279834 get weak and quit. They are really easy to replace. This short video show a normal Burst of heat from a dry and the normal length of time it fires off
May 19, 2010 | Whirlpool WGD5300S Dryer
Wirlpool AWD60A 6KG dryer and it doesnt dry clothes
clogged dryer venting run 1 load w/the venting removed to confirm
Apr 13, 2010 | Dryers
My printer doesnt print. i am told its because i havent used it enough. is this a problem i will always have with any injk jet printers. can i clean it at all
The ink will harden at the print head if allowed to sit for long periods. You can try taking a wet paper towel, put in the microwave get it really hot. Draw the cartridge over the hot wet towel (in one direction only) till the ink flows. Then take a dry paper towel and draw the head over it the same number of times. Make sure its dry and reinstall.
Nov 28, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
I have a kenmore elite HE2 dryer and it takes 2 or 3 times before the clothes are dry
know this may seem simple, but the lint filter needs to be cleaned after every load- some times twice- 'specially if you have cats, or heavy blankets, or lint prone fabrics. might try using vacuum cleaner to clean vent tube, or check external vent louvers. blocked or repressed airflow can really slow the drying process!
good luck!
Sep 08, 2009 | Dryers
Dryer doesnt heat up enough to dry clothes
sound like the vent duct going thru the wall to outside is stopped up / check your duct and outside dryer flap to make sure the air is open / if blocked it will take 2-3 times as long to dry and make it seem like the dryer isn't drying / larry
Dec 02, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Zanussi TD4112W Electric Dryer Logo
95 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
