Question about Frigidaire Washing Machines
Washer will not fill with water
Unitized unit
  • Frigidaire Master
  • 5,323 Answers
CHECK WATER INLET VALVE AND WATER PRESSURE SWITCH
Posted on Apr 01, 2015
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
shaggyrat
  • 1224 Answers
SOURCE: washer problems
this part underneath is the direct drive 3 dollars most washer part stores easy to install this is what had broken and it clicking underneath
Posted on May 29, 2008
  • 686 Answers
SOURCE: Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Posted on Apr 18, 2009
sclarke7
  • 222 Answers
SOURCE: maytag neptune washer hot water fill problem
replace the valve
Posted on Sep 04, 2009
  • 17 Answers
SOURCE: Whirlpool washer cold water takes forever to fill
Firstly check that the cold tap is turned fully on, u can also check that the strainer on the water inlet hose is not blocked (where it connects to machine) if they are ok it could be a water solinoid
Posted on Aug 11, 2010
Kenmore washer model 1102781269 over fills
Possible that the settings of the water level sensor is too high, you need to short the switch and see if the inlet flow stops. if not there are issues with the main controller unit.
Check this links for tips: controller unit
Nov 20, 2013 | Washing Machines
My FAFW3511KR front load washer won't spin on the wash cycle. It has error code 11
Hello Geri Witkowski - I understand that your washer displayed E11. Typically error code E11 indicates that either the unit is taking too long to fill with water or there is a possible leak.
· Try resetting the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit.
· Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
· If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Mar 18, 2013 | Frigidaire ATF6000ES Front Load Washer
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Washer does nothing
ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
