Question about Sony DAV-C900 System
Door will not open - Sony DAV-C900 System
When my garage door is in open position,it will go down about 2 ft. and return to open position with door connected to unit or not. It's a 3/4 hp Craftsman door Opener. Help please.
Try this...pull the door release cord. sb red, close the door manually all the way.
Push the door close button..when the unit stops re engage the emergency door release. open the door with the opener...close the door with the opener.
Hope this helps.
Dec 25, 2017 | Building Materials
Door handles wont open doors
Fixed 1997 Ford Explorer Door wont open - YouTube
? 2:03
https://www.youtube.com/watch?v=Gs3eC8E-gbU
Sep 6, 2014 - Uploaded by craiwin
I fixed my 1997 Ford Explorer Door won't open problem! ... I have the same problem but my passenger side door on my 2001 Ford Explorer locked and won't open smh ... will this work for the rear passenger doors? ... How to Replace Rear Inside Door Handle Latch Cable 2002-05 Ford Explorer Mercury ...
98 Ford Explorer Door Won't Open Part 1 - YouTube
? 0:30
https://www.youtube.com/watch?v=oY4IcNdGK68
Apr 5, 2010 - Uploaded by gdellinger
A couple weeks ago the door handle just stopped working on the... 98 Ford Explorer Door Won't Open Part 1 ... The remote would open all other doors. ... on a Ford Exploer 91-2001 - Duration: 7:27. by diversity2 37,309 views.
98 Ford Explorer Door Problems- how to open without panel ...
? 4:22
https://www.youtube.com/watch?v=lJ0Fsh3561s
Jan 1, 2013 - Uploaded by inwinblades
98 Ford Explorer Door Problems- how to open without panel removal. inwinblades .... HELLO panel removal??? door won't open... Been searching all ... ok this better work on all doors, im aboutt o try this on my rear passenger door. .... I didn't care about the plastic door handle so i just "busted" it to pieces.
Rear doors can't open from inside - Ford Explorer and R
Jan 05, 2016 | 2001 Ford Explorer
How to open the door if no electricity
Almost all garage door openers have a switch mechanism that will allow you to open the door manually. It is usually a pull cord on the motor or track. Pulling it down usually deactivates automatic mode. Just pull it up into position when the electricity comes back on.
Garage Door Repair in Jacksonville FL American Garage Doors LLC
Mar 17, 2015 | Building Materials
2005 malibu passengers door in closed position door will not open feels like dod is off how do you open door or remove door panel while door is closed
that's no fun removing one with the door closed.. Try everything first make sure key has door unlocked try to open from inside and outside. If not get a slim jim and try that to open door.. Taking door panel off with door closed is not good ..
Apr 06, 2014 | 2005 Chevrolet Malibu
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Opening mechanism inside front door not working - How do I get door open?
Parts are available at a salvage yard. Getting the door open is going to be your problem "unless" you pull the seat out and have room to take door panel off to open the door with the mechanism manually.
Sep 11, 2012 | 2000 Toyota Sienna
My power sliding door doesn't open fully. It makes clicking sound and a somewhat of a jerking motion. It open or closes slighty but the entire it makes the above mentioned noises. Any help would be...
I'm not sure about the noise, but the jerking motion might be because your the center roller (located in the rear middle of the sliding door) has worn out and need to be replace. This is a will known problem.
Your problem is very hard to answer because 05-10 odyssey has so many problem with sliding door.
rear latch:
-door not to latch close
-door not to work
front latch:
-door not to open
lock actuator:
-door not to open
-door will pop when opening
window motor:
-window not to work
-door will only open half way
center roller:
-jerking motion when opening
-door kick back close while opening
-door kick back open while closing
Door motor:
-door not to work
-cause door to jam
good luck
Dec 17, 2010 | 2005 Honda Odyssey
Fuel door won't open
ok check the sliding door on the side the fuel door is on. there is a safety mech. there the door needs to be closed all the way. if its not you can't open the fuel door. so slam that door then find out where and how it keeps the fuel door from opening. because if you open the door with the fuel door open it may damage fuel door
Jan 27, 2009 | 2002 Honda Odyssey
Open Questions:
Sony DAV-C900 Home Theater System: problems with speakers and dvd picture quality Hello all, I hope someone can help me here... The speakers have been going off and on intermittently for a while now. I have cleaned the connections, but it does no good. Sony has these stupid color coded connectors and I do not know how to go about upgrading the wires. If that is even the problem. I have switched the wires around, and when I switch one that works to a non-working connector it will not work. When I put a non-working speaker wire into one of the working connectors, it will work--it almost seems to me that it is either a problem internally, or with that specific connector that sticks out of the rear of the unit. After fooling around with them for a while, I can usually get it to work, but then it will go out for no apparent reason. Another problem has to do with the picture. It has developed these squiggly lines while watching dvd's. Sometimes they go away after a while, but it is certainly annoying. I have attempted to clean the laser with one of those dvd cleaning disc's and even replaced the s-video cable, but neither has resolved this problem. It used to have an excellent picture, even though I wasn't using component cables. Due to my TV set-up, I need to use the S-video hook-up, but like I said it has always worked well until recently... We really do not watch that many movies, so I wouldn't think the laser is going bad--hell, the kids have many more hours on their xbox than this unit has...If I had the money, I would just go out buy a new system--not an HTIB this time, but this year has not been too lucrative, so I am stuck with this for the time. Any help will be greatly appreciated. Thanks Dana
Feb 22, 2007 | Sony DAV-C900 System
Sony DAV-C900 System Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
