Question about Car Audio & Video
My fuse 1 keeps blowing on my 97 528i
My wipers stopped working, replace relays, wiper motor but fuse 1 keeps blowing
dddsouve
  • 64 Answers
SOURCE: windshield wipers in front wont work but rear wipers work
Hi! U need to check the switch and the wiring circuit that controls the motor.
Posted on Jan 15, 2009
wracefans24
  • 1985 Answers
SOURCE: windshield wipers keep blowing fuse
it is probably the wiper motor,its building up to much resistance and blowing your fuse
Posted on Jan 26, 2010
Testimonial: "thank you thats kinda what i figured i just wanted someone elses opinion thank you =)"
  • 1168 Answers
SOURCE: windshield wipers don't work.Fuse is good.
Hello Firerocker.
If your washer motor works there is power in the circuit and ground.
The wiper motor housing needs to be grounded.
If neither one works check for power on the green wire leading into the motor. If nothing there your switch may be bad.
If there is power to the green wire then check for power on the gray wire on low wiper speed and power on purple on high speed.
Here is a diagram if you need it.
http://i28.photobucket.com/albums/c227/Kiltylake/Wiper.gif
Hope this gets your wipers going again.
KL
Posted on Feb 12, 2010
  • 14036 Answers
SOURCE: Windshield Wiper motor or relay switch repair.
SOUND LIKE A BAD WIPER RELAY.CHECK IN YOUR OWNERS CAR MANUAL IN GLOVE COMPARTMENT IT HAS FUSES AND RELAY LOCATIONS AND THE CIRCUIT EACH CONTROLS.
Posted on Jun 18, 2010
  • 11800 Answers
SOURCE: 2001 Grand Cherokee window wipers
You must find out if the problem is in the motor of the wipers or the command and wiring to it: with the engine shut down engage the wipers at full speed; take a voltmeter, access the wiring to the motor and take it out and check the voltages between every single wire in there and the body of the car - if none of them has at least 12 volts then the wiring/ command is at fault, if there is 12 volts there the motor has failed.
If it's in the wiring the next step is to check the command: take out the steering shrouds and identify the wires going to the wiper switch. One of them will have always 12 volts, the others will get that as the lever is moved; if they don't then the switch is dead , replace it.
Posted on Nov 04, 2010
Wipers stopped working and keeps blowing the fuse.
Could be a short in the wiper motor. Does the fuse blow with the motor unplugged ?
Mar 04, 2014 | 1994 Buick Century
1997 Acura 2.5 TL wiper fuse keeps blowing
weak or faulty wiper motor, or wiper motor under heavy load, clean out snow ice and debri then retry wipers.
Dec 13, 2013 | 2000 Acura TL
My wipers stopped and the fuse blows as try to change it for a new one
Troubleshoot the wipers. First disconnect wipers from under the hood. Replace the fuse. If the fuse still burns out then the problem is with the harness. There is a short in one of the wires and will need to be replaced.
If you replace fuse and it does not burn, then the problem is with the wiper motor. You can possibly just replace the circuit board or replace the whole wiper motor.
Good Luck,
Israel Adame
Sep 07, 2011 | 2000 Hyundai Sonata
Yes my fuse for my wipers keeps blowing and my wipers turn on when i plug fuse in even know the wipers are turned off.
The power distribution box in the engine compartment # 6 , 30 amp mini - fuse , front wiper motor , front wiper relay , front washer pump , FEM ( also # 7 , 25 amp mini - fuse , rear wiper etc. ) The owners manual shows to disconnect your battery cables before servicing anything in the PD BOX
your relay could be shorted which makes the fuse keep blowing
Sep 05, 2011 | 2001 Ford Windstar
Windshield wipers keep blowing fuse
Jan 26, 2010 | 2000 Saturn L-Series
Keep blowing fuses for the wipers, have replaced
Your wiper motor is about to go out, if it hasen already, wiper motor pulling to many amps will cause the fuse to blow.
Dec 09, 2009 | 2003 Hyundai Accent
2001 sonata wiper fuse keeps blowing
If the fuse blows as soon as you put it in and the wipers are off then you have a short between the fuse block and the wiper switch.
If the fuse blows only when you turn the wipers on then more than likely the wiper motor has shorted and burned out. This one is very likely if the snow storm was heavy and you was driving in it. Cause- Moving large amounts of snow and ice off the window puts a heavy load on the wiper motors.
Jan 19, 2009 | 2001 Hyundai Sonata
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
