When I try to adjust the volume on my Ipod Nano under Settings it is asking me for a code. How do I reset the code or find out what the code is? Is there another way to increase the volume, it appears to be locked and is very low. I need to unlock the volume so that I can increase it. The screen I see is almost like a combination lock. Can you please help me?
Thanks,
Jennifer
If it is the unlock code plug your ipod into itunes then goto to settings for the device and click change password
Posted on Jan 02, 2008
When i try to adjust the volume on my ipod Nano under settings it is asking me for a code, how do i reset the code or find out what the code is? Is there another way to increase the volume it appears to be locked an is very low, I need to unlock the volume so that i can increase it.The screen i see is almost like a combination lock. can u please help me.
Thanks
kathleen
Posted on Oct 21, 2008
I had a problem with low volume when using the headphones supplied. I got a £15 JVC pair with built in bass boost. Now i enjoy listening to my tunes on the move as they should be. Scouser.
Posted on Jan 25, 2010
To bypass and reset the code, you have to plugin ipod and in Itunes say use as disk, after that go into the ipod folder via my computer and select show hidden files in extra (map options)
To see hidden files:
1.
On the Tools menu in Windows Explorer, click Folder Options.
2.
Click the View tab.
3.
Under Hidden files and folders, click Show hidden files and folders.
then go into ipodcontrol then Device and delete _volumeControl
voila !
grtz
Posted on Aug 18, 2009
If u forgot the code then u want to restore the factory settings,below i have pasted the link how to reset the code.
http://support.apple.com/kb/HT1339?viewlocale=en_US
Posted on Nov 19, 2008
Most likely it is a code that your parents, or whomever used to lock the volume thru itunes.
You would need to get it from them as there is no way to "hack" the password.
Best of Luck.
Posted on Oct 27, 2007
You need to restore your ipod back to the origional settings, you will lose your music but they can easilty be synced on again.
Posted on Nov 07, 2010
Please forward answer to low volume issue with sony headphones it. It just became a problem How do I correct it. They work fine on other devices. Send response to smcduffie@tmo.blackberry.net
Posted on Jul 27, 2010
I have th esame problem...and i wanted to ask how u can possibly change the code without knowing it in the first place??
Posted on Jun 03, 2008
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
3 Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Mar 16, 2010 | Apple iPod nano
Feb 15, 2010 | Apple iPod nano
Jun 09, 2009 | Apple iPod nano
Oct 13, 2008 | Apple iPod nano 3rd Generation
Sep 19, 2008 | Apple iPod nano 2nd Generation MP3 Player
Aug 01, 2008 | Apple iPod nano
Jul 25, 2008 | Apple iPod nano
7,173 people viewed this question
Same problem!!
pls help
there is a combination whereby i have no solution
I have the same problem regarding the volume code. The answer, to connect my computer to I i-tunes and change it from Device setting sounded great until I realized that I can not find this setting. Perhaps someone can tell me where. I have been wanting to fix this for quite some time, but since I moved to Italy it seams somewhatt more difficult to find a mac store
thank you
same problem
My volume setting used to go from 1-31 but now i only have 3 choices which are 5 10 and 15 and it is still very low. I dont know how the setting was changed but i would like to put it back. can you help?
My ipod nano shows that whenever I try to turn the volume up it shows a lock sign.And the volume is very low even if I try to turn it up all the way.And I also went under Settings and it asked me for a code.But I did not know the code to unlock it!I went online to get some answers.
when i want to adjust my volume at settings it ask for a combination code. Christin
my ipod appears to be on, and the song is playing but there is no sound there is no combo set on it... so I don't know what is going on w/ it
YEp same problem! :(
I HAVE SOME PROBLEM I DONT HAVE A CODE FOR THE VOLUME ON MY IPOD NANO
i have an 8gb ipod nano & i don't know if i inadvertanly did something or what. when i want to increse my volume,its got a padlock on the end.i don't recall seeing that before however what can i do so i can cofotably listen to my music,as you know some cd;s play loder/softer than others & i want to enjoy them all
