Question about Wella Color Charm Toner #T27
How do i get the yellow tint out of my hair - Wella Color Charm Toner #T27
How can I remove window tinting on rear window of my 1997 benz?
best talk with people who do the window tinting as they will be facing the problem all the time . They may suggest a hair drier to soften the tint film to assist with the removal
Aug 15, 2014 | 1997 Mercedes-Benz C-Class
How to rectify my hair colour used xxl absolute platinum roots are a lovely colour but rest of hair is orange suggestions in what i can do to rectify the problem
Where you tinting / coloring over a existing color?
It is real important that you navigate / calculate what your natural color level and what natural reflect your hair is. (Not artificially from a previous tint) Because tint is not total matt coverage like paint. Hair color wont tint over tint accurately. This is how many horrific bad colors are born.
If your eyes are blue or hazel & you have a fairer complexion that color is more feasible. If your eyes are brown and your hair is medium to coarser texture and very dark its a lot more complicated because you could throw scaling down (backwards) from lots of red to brassy copper to gold.
The actual formula needed is calculated on how many shade levels of lift counteracted by what reflect your lightened hair will throw. Not necessarily by what color the tint box says. The color shade on the box is a idealistic situation. If your having trouble following me or these complexities cut about 50 strands of hair at the nape (back of neck underneath your hair and put scotch tape around it. Then mix a minute amount of color and developer and you will understand me. This way you can at worse only screw up of 50 strands of hair (instead of everything attached to your head). Bad hair color jobs are expensive to fix & as I can see what we are working with a guess is a hazard. Don't take on almost mission impossible blindly.
Jun 04, 2014 | Schwarzkopf Essensity Permanent Hair...
I want my hair this color by wella
Apr 07, 2014 | Wella Professional Hair Color & Developer...
How do you remove the yellow tint from gray or silver hair?
You can only remove it by bleaching it. Usually though, we merely neutralize yellow by applying a permanent tint, demi-permanent color, semi-permanent rinse, or a colored shampoo in a complementary color, that is a hue that is opposite yellow on the color wheel. The hue most often used is violet.
Apr 10, 2011 | Health & Beauty
Why is it when im colouring with 6rr the colour isnt as vibrant as it is the colour chart?
When tinting hair the resulting color will always be a combination of the previously existing hair color and the artificial color that is applied. There are too many factors to cover hypothetically here. But a few of the most common factors are the condition of the hair, previous tint in the hair, percentage of grey in the hair, whether or not the tint used is a permanent or demi permanent tint, and finally whether or not the light/dark level of the artificial hair color is properly matched to the existing color or colors in the hair.
Apr 07, 2011 | Health & Beauty
My hdtv has a yellow tint to it.is my bulb going bad?
i think not yet.the circuit for that has faulty parts.try bring it to a tech.
May 28, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Yellow Tint on Lower Right Side of Sony KDS-R60XBR1 TV Screen
Hi, Sony will repair your TV free of cost for yellow tint problem. Click Sony Support for details.
Jan 05, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
Nov 27, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
Wella Color Charm Toner #T27 Logo
18 people viewed this question
Top Wella Health & Beauty Experts
Steve Macqueen
Steve Macqueen
Stan Ford
ray gallant
Are you a Wella Health and Beauty Expert? Answer questions, earn points and help others
