Question about Nikon COOLPIX Cameras
Nikon Coolpix card not accepted
Brand new Coolpix camera won't accept SD card
  • 69 Answers
SOURCE: Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Posted on Dec 20, 2008
  • 60 Answers
SOURCE: Will not accept a SD Card now.
first are you still under warranty, if you are don t tell nikon it was dropped they may not cover it if it was dropped. Tell them it stopped reading cards all of a sudden. See if they can fix. If warranty is up may need to get it repaired yourself.i had similar problem with other name brand camera. i didnt fix though was inexpensive camera. I know nikons are high in price so you may want to get fixed.
Posted on Aug 12, 2009
  • 11967 Answers
SOURCE: My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Posted on Jun 07, 2010
lock123
  • 6831 Answers
SOURCE: Camera won't accept an SD Memory Card anymore
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
t00nz
  • 4738 Answers
SOURCE: I can't get the camera to accept a sd memory card.
Are you using a 4GB or higher "SDHC" card with your camera? Note that the S800 can only use "standard" SD cards (those 2GB or less). Fortunately, these are very inexpensive these days, recommend checking on Amazon.
For those that encounter this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Jan 05, 2011
How much memmory support does it provide nikon coolpix p4 vr
The P4 has about 23MB of internal memory, which might hold five pictures at the camera's best resolution. The camera also accepts SD cards up to 2GB in size, which should hold several hundred pictures. And, of course, you can use multiple cards.
Jan 04, 2011 | Nikon COOLPIX L18 Digital Camera
My Nikon Coolpix P3 camera is not accepting my 4GB, SDHC San disk card?
The P3 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to go with SD cards, 2GB and smaller.
Dec 05, 2010 | Nikon COOLPIX P3 Digital Camera
My coolpix 3200 will not accept a SD card. it rejected the 128 mb card and I replaced it with a 4g card that it doesn't like either. It also will not allow me to format any SD cards
The 3200 works with SD cards. Your 4GB cards is actually an SDHC card, which is electronically incompatible. You need to use SD cards, 2GB and smaller.
Oct 21, 2010 | Nikon Coolpix 3200 Digital Camera
I Purchased a new SDHC card from Argos which was 4 GB as the one that came with my Nikon coolpix 3700 is a 16mb I put this new one into my camera and the camera showed that you couldn't use this card,...
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Please take a moment to rate my free answer.
Oct 06, 2010 | Nikon Coolpix 3700 Coolpix 4200 Coolpix...
Nikon coolpix 3100 - maximum card support?
yes you would. It can inly accept 1GB cards. Just as a tip large capacity cards make it slow to recover from a write after taking a pic so if you can get say 512K cards still use those they recover from writing a lot faster
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Nikon COOLPIX Cameras
It says this card cannot be used. what is the biggest sd card i can use?
The S1 uses SD cards. SD cards top out at 2GB, any larger cards are actually SDHC (Secure Digital High Capacity). SDHC devices will accept SD cards, but SD devices will not accept SDHC cards. They will fit physically but not electronically.
In fact, the S1 manual does not list any cards larger than 1GB.
Jan 26, 2010 | Nikon Coolpix S1 Digital Camera
Aug 12, 2009 | Nikon D40x Digital Camera
4gb not compatable?
camera wont accept a 4gb card most only take 2 gb sd cards .
Jun 03, 2009 | Nikon Coolpix 5000 Digital Camera
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
Cameras Logo
12 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
