Question about Dell 2335dn Multifunction Laser Printer
Loading paper How do I load 4 x 6 index cards into the printer?
    Problem Solver:
  • 8 Answers
In this particular case you want to use the "By-Pass Feeder". Open the first door where the toner cartridge goes. There are two sliders narrow them down to the width of the index cards with a few in-between them. Once you do this it should auto select them when you print as long as you tell the docement in the properties that it should select the by pass feeder. It must be selected in the document properties or you will be changing settings constantly for the printer. Please let me know if I need to explain in better detail.
Posted on Apr 27, 2014
5 Suggested Answers
  • 40 Answers
SOURCE: PAPER WONT LOAD
Greetings,
I beleive troubleshooting with simple proceedures. Try alcohol on the rollers and Canned air in the paper load area. Trust me it works.
Regards,
techSup1
Posted on May 01, 2009
  • 158 Answers
SOURCE: load mpf paper
Your printer is set to default to the Main Paper Feeder, which is probably set for letter size paper. You must tell it to feed cards. On your Windows Desktop, left click mouse on START. left click on CONTROL PANEL, and left click on the PRINTERS icon. On the PRINTERS screen, RIGHT CLICK on your Dell printer icon. On the drop down menu, left click on PRINTING PREFERENCES. On the PRINTING PREFERENCES window, left click on the PAPER/QUALITY tab. Under TRAY SELECTION, choose the PAPER SOURCE where you want your business cards to feed from. Left click on APPLY button. Next, left click on the ADVANCED button. On the ADVANCED OPTIONS window, use the drop-down box next to PAPER SIZE to choose the paper size you want to feed. Press OK button. The PRINTING PREFERENCES window will now reappear. Left click APPLY, then OK buttons. After you have printed your cards, be sure to restore the printer defaults back to their original state, or the printer may jam because it must be programmed for the paper size being used. If you reload letter paper without resetting the paper size, the printer will think there is still card sized paper in the tray, and it will issue a jam or error code until the paper size is set properly.
Posted on Aug 06, 2008
nassimjd
  • 104 Answers
SOURCE: Printer loads paper incorrectly when trying to print
in the tray where you put the paper, there are two pieces of plastic that site on the side ,,,,, bring them close to the paper as to touch the paper.
this way the paper cannot go left or right when loaded and now will go in straight.
this oughta do it.
Posted on Mar 26, 2009
ted1430
  • 339 Answers
SOURCE: I need to print 5X8 index cards on my Dell 1720dn.
Are you using the manual feed slot in front of the printer and setting the paper size properly in your software? 3x5 is supported by Dell so this should work.
Posted on Aug 28, 2009
Paper wont load straight
To help you troubleshoot paper jam issue, please find the link given below and follow the step-by-step instructions,
https://support.usa.canon.com/kb/index?page=content&id=ART109173
GuruAid.com
Jun 06, 2016 | Canon MG5250 Printer
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I need to print 5X8 index cards on my Dell 1720dn. No matter how I load the cards, it says I'm out of paper
Aug 28, 2009 | Dell 1720dn Laser Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Paper jam
Also see this:
    Note:
Top
Top
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing on an index card
something else you might try is taping the card to a full-size sheet of paper, so the printer can push it through with ALL the rollers at the same time. not all printers have a roller all the way across, so index cards get snagged by one side, and they'll walk to the opposite side while they're printing.
Jun 12, 2009 | Ricoh Office Equipment & Supplies
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Printer will not print 4X6" pictures.
Loading index cards, post cards, and 4 x 6-inch photo paper Remove the paper output tray and all paper from the paper supply tray. Slide a stack of cards into the paper supply tray until they stop. Make sure the print side is face down. Adjust the paper-width guide against the cards, and then slide the paper-length guide in until it stops. Make sure the cards fit within the tray (do not overload it), and then reinstall the paper output tray. Figure 3: Loading a stack of cards 80455c3.jpg
Nov 10, 2007 | HP PSC 1410 All-In-One InkJet Printer
Dell 2335dn Multifunction Laser Printer Logo
32 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
