Question about LG Radio Communications
Headset play, farst forward pause and back buttons do not activate on headset when pressed but call functions are working
The play media features are not working on the headset but the call features are working
  • 27 Answers
SOURCE: GE HO98058 Keyboard Special Function Hot Keys
I'm not familiar with JetAudio, however in most media players you can choose for that to be the default player. I would make sure it is your default player first and then try to use it with the keyboard. The instruction manual only mentions compatibility with Windows Media Player though so it just may not work.
Posted on Aug 29, 2007
  • 74 Answers
SOURCE: Additional dvd features (scan forward/backward, display) won't work
It may not be possible with that remote. If you lost the original then consider a new one at:
http://www.replacementremotes.com
Posted on Mar 25, 2008
charles0285
  • 160 Answers
SOURCE: HS 850 won't go into pairing mode
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
Posted on May 10, 2008
SOURCE: Nortel T7316E, How to make headset work ?
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
  1. Press Function **266344
  2. Than enter system coordinator pass word
  3. Press SHOW once and enter your phone extension number
  4. Press SHOW twice
  5. Press NEXT tree times
  6. Change the parameter at HANDFREE with MOD
  7. Set it at AUTO
I beleved this will FIX it OK!
Posted on Feb 17, 2009
shynysaxena
  • 166 Answers
SOURCE: Media control buttons doesn't work???
Actually many laptops & their media are designed only for working with XP or previous versions. So its not neccessary that they work good with Vista also. Its true that they should be compatible with Vista but not very necessary. So you may need to change your OS again to access all functionality.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
Is there a random play feature on the sparkle b570 , if so how do i get to it?
The Sparkle b570 does not have a random / shuffle feature, most bluetooth headsets will only have basic, play, pause, next, back, answer call, hang up call. features.
If you want random play, you may have to choose this options on the device your headset is paired with (Cell phone, stereo, computer)
Nov 20, 2014 | Radio Communications
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Operating manual for Plain Lazy Alarm Clock iPhone/iPod Speaker Dock
No instruction manuals for the 'Plain Lazy' ipod docking station/alarm clock found on line :-( So after tinkering with the buttons for quite a while, II have worked out how to set the clock. Press & hold the play/pause button & at the same time press the skip back button once....let go of both buttons. Then immediately press the play/pause button again once & the clock numbers will start flashing. Press the skip back button to adjust the hours & skip forward button to adjust the minutes. Press the play/pause button to set!
Aug 04, 2012 | Audio Players & Recorders
All working just won't pause or play with the button
To use this feature on the 903+ you must only tap it one time, on the music icon. If this still does not work I would get a replacement for the product from the vendor whom you purchased this through. See the link below for more help.
Plantronics BackBeat 903 User's Guide
Good luck from Headsets Direct!
Nov 10, 2011 | Plantronics Backbeat 903 Bluetooth...
A friend gave me a zen stone 2gb and he lost the manual. I can't even figure out how,to turn it on. HELP!
If you plug your Zen to a PC and connect to the autodetect feature of Creative Labs at the below link you then can download the manual, use the knowledgebase, read the FAQ and even update the firmware and drivers for it.
http://support.creative.com/downloads/SoftwareAutoUpdate.aspx
I hope I helped you
Regards,
PDG
May 10, 2010 | Creative Labs ZEN Stone MP3 Player
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
I can't find FM radio in my samsung YP-U5
Press the button with the returning arrow at the top. The use the skip forwards and back buttons until you see the FM radio function. Press the play button to activate and once in you can use the forward and back buttons to scan for stations.
If this doesn't work, you could download emodio and update the firmware.
Feb 21, 2010 | Samsung YP-U5 MP3 Player
Sansa Clip Won't come from pause.
It might be a firmware issue you are having..Try going to the sandisk website to obtain a firmware update for your device..
I hope that helps
Thank you
Mar 04, 2009 | SanDisk Sansa Clip MP3 Player
Jabra Vibrate Feature
from the manual at http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Call vibrate*
• Call vibrate is automatically activated when you turn on your headset.
• To disable the call vibrate feature, press the answer/end button and
press the volume down (-) button at the same time.
• To reactivate the call vibrate feature, press the answer/end button and
press the volume up (+) button at the same time.
Dec 19, 2007 | Jabra BT350 Bluetooth Headset Headset
No sound from a known working headset on my ipod shuffle 1st generation
The light should be Hoff when operating, and if you pause it it will blink. If you hold the play/pause button you will lock the keypad. this is to prevent accidental skipping/stoping/volumae changes while having it on your pocket. Hold the play button for two seconds or more to activate/deactivate this function. -Chris
Feb 26, 2007 | Apple iPod shuffle MP3 Player
Radio Communications Logo
12 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
