Question about Samsung DV331AEW Dryer
Samsung front load dryer is stuck on cooling cycle
The water spray for steam cycle in Samsung front load dryer smells musty. The clothes smell bad from steam cycle only.
water build up in the steam water resevore sitting to long and getting that mildew smell check the hose lines going into it and from it. for blockage
May 27, 2014 | Samsung Dryers
Turning off and on in timed cycle
Sounds like you have it on wrinkle prevent, a feature that keeps your clothes from wrinkling before you pull them out of the dryer. Check your user manual.
Nov 07, 2013 | Samsung Dryers
Daewoo electric dryer is stuck on "cooling"
-You mean it's working but Only cold air...?
-If so. Possibly the heater element is burn out.
Good Luck
Mai
Oct 11, 2013 | Daewoo DWRWE33WS Front-Load Electric Dryer...
Bra stuck in lint trap housing on samsung front load dryer
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Jan 22, 2013 | Samsung WF337AA Front Load Washer
Digital timer stuck on 10 min.won't start the spin cycle
I know this isn't the solution you were hoping for but here is the manual for your machine:
http://www.samsung.com/ca/consumer/home-appliances/washers-dryers/washers/WF203ANW/XAC-supportforward
You say it rotates L & R...do you mean it agitates but the timer isn't advancing?
Dec 30, 2012 | Samsung WF203ANW Front Load Washer
Need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
Apr 29, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Feb 12, 2009 | Samsung WF337AA Front Load Washer
Samsung DV331AEW Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
