Question about Electrolux Epic 6500 Vacuum
I Sucked up the cap from the toilet any ideas it's stuck in the handle
Got a small rubber squeezable ball stuck about 2-3 inches from opening Miele silver moon
Take a 3 inch drywall screw or deck screw and screw it into the ball. Make sure that you thread into the ball about at least a half inch. Slowly work Out the ball backwads
Dec 04, 2016 | Vacuums
My Dirt Devil Reaction vacuum cleaner has a plugged hose.
Hi! A broom stick or something similar is probably the best tool you can use to remove a clog. Try pushing the broomstick in an up and down motion gently against the clog until it starts to loosen and slide out. If you are unable to remove the clog the hose can be replaced. I have included a link where you may go to purchase a replacement hose if needed. Good luck!
Search
Jun 06, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
I have a piece of wood stuck in the wand. How do I get it out?
Dear Kathleen, On this unit, check, inspect and clean from top to bottom - click red handle button and remove, squeeze tabs to remove hose, click red extension wand and remove, squeeze tabs to remove small bottom hose. Sorry for the late response,
Mar 14, 2014 | Shark Navigator Bagless Upright Vacuum
I accidently sucked up a pen cap and it stopped working then it began smoking and the belt snapped??
Take the pen cap out of where it is stuck and replace the belt. Most likely the smoke was from the belt slipping around the gear and getting hot. Did the smoke smell like burning rubber?
Oct 01, 2009 | Bissell 3576 CleanView II Bagless Upright...
I sucked up a piece of plastic. Removed plastic.
This style machine picks up the dirt/debris with the roller, sends it through a fan and into the bag/cup. This is a very common problem since a plastic fan turning at 2000 rpm meeting anything hard is going to cause damage. (Loose Change, toys, anything small) This fan creates your suction and when it is damaged it creates none, it also is the "noisy" part of any vacuum and becomes extremely noisy when damaged.
To Replace this part:
  1. Remove hood (4 screws underneath)
  2. Remove handle assembly ( one bolt through handle and slide off)
  3. remove the belt
  4. Remove the 2 brackets on each side of the motor that hold it in place. (4 screws)
  5. Lift motor off base assy.
  6. Remove rubber cuff around top of motor assy.
  7. Remove the 6 screws on large size of motor assy. and remove cap.
  8. Turn fan (or whats left of it) off of spindle by holding belt drive spindle on oppisite side of the motor.
  9. Replace fan and reassemble.
You can also take this to most any Hoover authorized service center, they would have the parts in stock and could probably do it for less than 50 dollars. Check their dealer locator for a local center.
Best of Luck!
Jun 09, 2009 | Hoover U5290-900 Upright Vacuum
Piece of chalk sucked into vacuum
Yes, it is stuck somewhere in the vacuum. Turn it upside down, and you will probably find it lodged. Also could be lodged in hose somewhere.
Jimh
Jun 01, 2009 | Dirt Devil Vacuums
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
Clogged hose and can not get the handle off
The best way to fix this problem is to Stick the other end of the handle into the wall inlet making the nozzle contact the pin jacks of the wall inlet. You may need to work the clog back and forth by then plugging the hose in normally. Eventually you will be able to work the clog out of the hose.
If all else fails you should use a plumbers snake.
Jan 06, 2009 | Electrolux Central Vacuum
Toy stuck in hose
Generally, this is a job for patience!  First, remove the hose from the unit.  Try a broom handle to push the toy out...you will not damage the hose.  If that doesn't work, you can use a piece of stiff wire fed through the hose with hooked end.  An electrician's fishtape...a snake...is often useful.
Nov 15, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Hoover Agility steam cleaner
Sounds like you have a broken water line, or it just came off. You would have to remove the top housing to get to the water lines. Or at the bottom of where the solution tank sits on, is the reservior asm. there are lines going there also. Bottom of the tank, the valve is stuck open. The trigger on the handle is stuck pushing down on the reservior asm.
Jan 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
