Question about Identity Asure ID Express ID Card Software
Create card record table failed - Identity Asure ID Express ID Card Software
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
May 24, 2014 | Televison & Video
Tip
Dreamweaver Thought that Teaches You, to search a database with phpmysql...
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from www.interakt.ro its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type.
Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes.
That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php.
Create new recordset in dw like this
SELECT "
FROM table WHERE table.column.you.r.searching LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword.
Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page...
Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply...
So now You have page with results. Test it and see if its working.
If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>.
As for details page recordset it should look like
SELECT *
FROM table
WHERE table.id = 'colname'
create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id']
and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something...
Home I did helped You.
on Jan 21, 2010 | Computers & Internet
Having troube with my FOREIGN KEYs on two tables.
I suggest you visit this website you will get the solution, I tried and it worked.
http://bit.ly/1bUVmuW
Nov 25, 2013 | Computers & Internet
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Apr 09, 2009 | Microsoft Computers & Internet
How do copy a table from an access database in one folder to another access database in another folder through visual basic code
Simple method Open both tables (or create second) and copy each record from source to target through 'do while not eof' or 'for each' syntax.
Second solution create link in target DB for first table, and use SELECT INTO statment in SQL.
Mar 02, 2009 | Microsoft Visual Basic 6.0 for PC
Automatic focus on Butting Target failed
Hi!. You need to create tables using the Oxyjen Installion Utlities. Make sure that your Calibration side is positioned properly and the four foucus types are calibrated. Once the tables are created, save them to the appropriate tables folder.
Oct 07, 2008 | CreoScitex EverSmart Jazz+ Flatbed Scanner
Need to Know fully info about Macros
Macro is a simple way to automate tasks in Microsoft Office programs. It allows advanced users to program or create their own commands in Office, thereby automating tasks. For example, a user might want to create a table with four values already in them. The user could create one, and then copy it, and paste it. However, when you restart your computer, that data is lost. Unless you open the old document and copy the table, you'll have to start all over again. Macros helps you do your tasks. By recording the table creation to a macro, creating the same table over and over is just a simple macro away.
Sep 26, 2007 | Microsoft Office Standard for PC
How to activate command buttons II
Hi Lensa, The code is fine there should not be any problem with it. Do not change anything on it. In my opinion the buttons and code has nothing to do with it since they are done automatically and usually work fine. When you press the add new button you are not just creating a new record you are also updating the last record. This button just send you to a new empty record for you to fill. From my experience the error message is due to 3 major reasons: 1. Your record source for this form is a query that cannot be updated 2. You don't have writing permissions to the database. Check and see if the file is locked or its on read only, Check security options and see if the database is read only etc. 3. Your records are locked by the table setting for some reasons, primary key fields might create duplicates. If its just a table try updating the table without a form and see what happens. As I wrote above the problem is with the record source or the database and since I can't see what you have there I can't help you further. I would also suggest you should practice with a simple table first before going into advance queries. Create a table with some simple fields like: ID - Primary key - Auto Number First name - Text Last name - Text Then create a form of that table and start filling in the names and test all the buttons, that will give you an idea of each button and I am sure it will be easier. Good luck Daniel
Aug 16, 2007 | Microsoft Office Standard for PC
Outlook calendar sync error: 03-0058
Did you get a solution to this? I'm in exactly the same situation and nothing is fixing it.
Sep 11, 2005 | Palm Treo 650 Handheld
Identity Asure ID Express ID Card Software  Logo
114 people viewed this question
Top Identity Computers & Internet Experts
tosin_christ
NOEL
NOEL
Mishan Kasiparsad
Are you an Identity Computer and Internet Expert? Answer questions, earn points and help others
