Maytag washer lat8006aae
Brake down
Drain pump will not drain tub,but if i place drain hose on ground,tub drains with full hose.is the pump belt drive,or transmission shaft driven.thanks bob
check underneath but normally the pump is a stand alone unit at the bottom of the tub
it gets its power from the program board when it is progressed from wash to spin
problems that stop it from working mostly come from items stuck in the pump impeller preventing the motor from spinning
look for coins , hair pins , bra wires etc that get lodged in the pump housing
Oct 18, 2016 | Maytag Washing Machines
My washing machine,only on spin cycle,kicks breaker off,it does'nt kick breaker off on any other cycle?
yes in spin cycle the drain valve solenoid is open (on) how else would it get rid of water it spins out , id look real careful at this device I'll bet there's some sort of visual evidence of a problem there (rust.heat marks, wet )
Jun 03, 2015 | Maytag Washing Machines
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
Feb 07, 2015 | Maytag Washing Machines
Maytag washer leaking below drum
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jan 16, 2013 | Maytag Washing Machines
If my washer makes a squealing sound during the spin cycle would the noted parts still need to be replaced, brake stator, brake rotor and lining and snubber?
one of the above. Tip the washer back and turn the main drive pulley while spraying a little WD-40 in there. That will quiet down the washer.
More here
Sep 20, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag model LAT8006AAE won't complete spinning water out. Stops and won't advance any farther. It does this on both long and short cycles.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 18, 2011 | Maytag Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer
Take motor and pump assembly off and turn upside down. Soak shaft with lube oil,wd40 ect.
should pull straight up. They are known to stick and brake,(the pump)so be gentle.
Jan 13, 2009 | Maytag SAV5710 Top Load Washer
Maytag washer sqealing
hi Garrett,
sounds like a frozen gearbox. check the pulley that is being driven by the motor or by the secondary belt that you are saying. it could be the gear box broke and would not spin. another thing to look at once the gearbox is down is the brake mechanism. it could have broke down and would not run because the brake is not yet released.
tnx 4 using fixya,
drcool
Nov 14, 2008 | Maytag MAV6300 Top Load Washer
Maytag washer sav models
If you have the topload maytag as listed, It is possible for a transmission to have both symptoms, but it doesn't usually happen as you describe. If something came apart inside the clutch causing the shaft to pull up and keep the brake released, but also allowed the clutch to slip, this is possible.
I would suspect a brake or thrust bearing or both before a transmission. If you are able to turn the basket easily by hand, the brake is not applying for some reason. The thrust bearing will wear down so that it doesn't completely release the brake causing a slow spin. I find these two parts to cause more trouble than transmissions, but I do find bad transmissions occasionaly also.  Post back if you want to know how to check them.
Oct 17, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
