Question about Nikon Nivo 3.C Reflectorless Total Station 3-Second
Nivo horizontal losing horizontal azimuth when rotated
WHAT IS THE HYPOTAMUM OF A RIGHT ANGLE TRIANGLE 180CM X 180CM
I think you're asking about a "hypotenuse", not a "hypotamum". The hypotenuse of a right triangle with those dimensions would be 180 x the square root of 2, or approximately 254.52cm.
Jul 13, 2014 | Nikon Nivo 3M 3" Reflectroless Total...
Nedavno sam napunio cetridz 27 color i sada mi ne printa a pokazu je mi da je ketridz pun do vrha izvadim cetridz znaci nije u printeru opet pokazuje da je unutra i da je pun probam isprintati test...
Pokušajte za ?iš?enje mlaznica spremnika s tintom pomo?u ra?unala. U?itaj obi?nom papiru. Otvorite centar Lexmark Solution (idite na Start, Programs, Lexmark XXXX serije, Lexmark Solution Center). Od Odr?avanje karticu, kliknite Clean popraviti horizontalne pruge. Kliknite Ispis. mlaznica stranici ispisuje, prisiljavaju?i tinte kroz o?istiti za?epljene mlaznice. Ispišite dokument opet kako bi provjerili da je kvaliteta tiska je poboljšana. Ako se kvaliteta ispisa nije poboljšalo, pokušajte ?iš?enje mlaznica tintom i do dva puta.
Napomena: Ovo je prera?unavaju translate.google.com.
May 03, 2011 | Lexmark X1150 All-In-One InkJet Printer
I try to use my old Sony CCD-V5 video camera recoder to play some old V8 tapes but the the frames are not steady. There are horizontal bars on the screean. Could you let me know how to fix it?
try to clean head-drum with a cleaning tape, if it does not help the head is worn or some tape azimuth problem exists.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 20, 2011 | Sony Televison & Video
The Celestron Nexstar 4SE makes a weird cracking noise when you press the left or right arrows on the controller. I tried taking it off of the tripod, and it still will not rotate left or right, even if...
Is the AZimuth clutch locked down? Then either a gear is broken inside or the worm gear inside has slipped and is not engaing. You can return these to Celestron for repair, here:
http://www.celestron.com/c3/page.php?PageID=37
Dec 26, 2010 | Celestron NexStar 4 SE Telescope
When I started to make the azimuth motor rotate, it rotate, suddenly it stopped and warned me.. motor stalled.. With a message of what cold be the causes, but I can restart all the process without moving...
First, always use a seperate 12 volt power pack and NOT the internal batteries. Do a Calibrate Motors -- first thing whenever you turn on the telescope.
Sep 30, 2010 | Meade LX200GPS Telescope
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
I also purchased a used Meade ETX-70, only to find it had the same problem with the rotation axis motor running but no movement. After removing the bottom cover, I found the motor w/worm gear would not contact the main rotation gear. I solved the problem but purchasing a small 3/8x3/4x.032 spring that I had to custom fit to hold the motor w/worm gear against the rotation gear. Take caution not to have the spring apply to much pressure or it will cause to much drag.
To gain access, remove the bottom round cover(it will just pop off).
Then use a small .05 allen wrench to remove the set screw in the horizonal chrome lock. The chrome lock fits over a 1/2" bolt. By removing this bolt you will remove the washer/bearing assembly. After removing this, you will see a nylon nut, use a 11/16 socket to remove. Becareful, it is a fine thread and you don't want to cross thread it!
After you remove this, you will be able to remove the bottom housing, which will expose the motor and gear. You should be able to see what I am referring and where to place the spring.
If you can make it this far, then you should be able to install the spring. I used a little small dab of Gorilla glue to hold it in place, since the spring will have enough constant tension to keep it from moving.
I'm not sure if this was a design flaw, but I got no help from the Techs at Meade, only that they would upgrade to a ETX-80 for $149.99 plus shipping.
Hope this helps.......
Aug 12, 2008 | Meade ETX-70 (240 x 70mm) Telescope
Azimuth Head adjust
IT IS THE ***** IN SIDE OF HEAD ASSEMBLY BRING A SMALL SIZE SCEWDRIVER AND MAKE FINE ADJUSTEMENT UNTIL YOU GET BEST SOUND LEVEL
Feb 23, 2008 | Audio Players & Recorders
Re; Model # AV27765
Wait one second here if the ic wasent producing horiz drive you wouldny be getting any picture.. Your saying the set is floating the picture side ways?? your gonna need a scope to see where your losing the horizotal sync pulse from my friend.. No insult intended but if you have no horizontal drive there would be no High voltage therefore no picture.
Apr 01, 2006 | JVC AV-27432 27" TV
Nikon Nivo 3.C Reflectorless Total Station 3-Second Logo
108 people viewed this question
Top Nikon Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Nikon Retail Supply Expert? Answer questions, earn points and help others
