Question about Kitchen Ranges
Fisher & Paykel Classic FP653AWS 87111 MKD165092 How do I adjust oven door hinges? I replaced the oven seal but there is still a gap.
  • 1462 Answers
SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Posted on Mar 20, 2007
SOURCE: Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Posted on Dec 05, 2007
vitg55
  • 70 Answers
SOURCE: adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Posted on Nov 30, 2008
SOURCE: I have a Simpson Atlas
The springs in the hinges are probably tired. There is no adjustment you need to buy new hinges for about $50 for a set. Changing the hinges is a fairly simple operation for a person of average dexterity. I've just done the job on our oven.
Posted on Jan 03, 2009
Oven door on F@P oven not sealing
Check seal on door, and then see if your hinges are adjustable,
May 30, 2014 | Fisher Paykel Fisher & Paykel OB24SDPX1...
How to set up ovendoor
Check to see if you can adjust the hinges, it sounds like you also may not have the door completely set on the hinges
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
Door dropped and dont seal good
The door hinges are adjustable to correct sagging and poor sealing
Jan 02, 2013 | Fisher and Paykel Refrigerators
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Oven door fails to close properly. Heat escapes when cooking. Seals appear to be ok. Please assist if free, as offered.
Probably mal-adjusted hinges. Open the door fully and there USUALLY are small holes in the hinges to insert a nail into to hold the hinges open while working on the door.
Nov 25, 2009 | Fisher Ovens
Slack oven door on Tecnik 8085
The hinges cannot be adjusted, the only solution is to replace both hinges.
Plz rate my comments.
Thankyou..
Jan 05, 2009 | Tecnik Ovens
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
