Sharp mxm 623 makes blank copies - Office Equipment & Supplies
2 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not.
Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get.
If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings.
Are the strings broken , is the roller in place?
Posted on Oct 25, 2007
How to fix f2-22 error in sharp mxm 1054 copier
check the toner and or drum cartridge if third party replace with OEM
Sep 22, 2015 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
Install toner
toner not supply properly. please change chip for this copier
Apr 16, 2014 | Sharp Mx-M450 Copier
Sharp mxm 550 u code u-2 91
try removing memory see if it goes away, if yes replaced memory.
remove, turn off put back in turn on see if it comes back
U2-91 PCU section memory sum check error Crop 16
Apr 08, 2014 | Sharp Office Equipment & Supplies
Update video card
Interesting.
The HP Pavilion dv4000 series of Notebook PC's use the MXM-SIG MXM technology.
(Mobile pci-eXpress Module,
http://en.wikipedia.org/wiki/MXM
Nvidia made the MXM module for the Pavilion dv4000 series of Notebook PC's.
It is an Nvidia G73M-256
(The M stands for Mobile. Laptops are mobile devices. The 256 stands for the graphics memory amount in MegaBytes. {MB) This is a unit from the Nvidia GeForce G0 7600 graphics controller)
This is the motherboard. An Asus A8SN-CF (Phoenix)
http://h10010.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00858789&product=1132535#N159
(Click on Video)
This is information about MXM upgrades,
http://www.mxm-upgrade.com/
Since Nvidia no longer directly supports the MXM platform, but does it through MXM-SIG, these guy's are the ones to ask IMHO.
Regards,
joecoolvette
Jun 26, 2011 | HP Pavilion dv4000 Notebook
Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Nov 03, 2009 | Sharp Office Equipment & Supplies
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
12 people viewed this question
jasbo
jasbo
