Question about Lakewood Oil-Filled Electric Radiator Heater
Switch burn ed up need replacement
Where can I get a switch
Error code f74
Water pressure switch is staying closed. THe water valve needs to be replaced, or the relay (electrical switch) for it needs to be replaced.
Dec 02, 2013 | Gaggenau ED 220/221 Electric Single Oven
Menu keeps coming up on toshiba regza 32
Check the menu button on the front panel of the TV. It it has been struck ed, this kind of fault can occur. If found struck ed, replace the micro switch inside.
Jul 22, 2012 | LG 42LC2D 42 in. LCD HDTV
The clock light in my MicroSystem cd burned out. Can it be replaced?
Yes it can! but in order to replace the bulb the unit must be taken apart and the old one removed from behind the LCD display that is sold-ed in.
May 21, 2011 | Boston Acoustics (MICROSYSTEMCD) Shelf...
Window motor on drivers side constantly runs down
Best guess would be a shorted window switch, it may have moisture in the switch or the wires are shorted or the switch needs to be replaced.
Hope this is of some help.
Ed
Mar 29, 2010 | 2005 Chevrolet Equinox
Oven was put on clean mode after about 1hour 30 min started peeping and display shows f-9
Hello-  The code indicated- F9 - indicates a fault in the door lock circuit. The usual part that fails is a little switch by the latch. The full-power extended cycle burned out the contacts. The part is available, but fairly difficult to replace, so consider service. If this is the only problem you have after 'self-cleaning', consider yourself lucky. This cycle is called 'self-destruct' by most techs.      Please acknowledge this post if the info is helpful- have more if needed.  Thanks- Ed
Mar 23, 2010 | Kenmore Ovens
Used the selfcleaning feature. now it won't stop beeping and the oven door is locked. we have tried to unplug the oven, still nothing has changed. there is an error displayed. Please help!
HI- Sorry-No good news here. Techs call this feature 'Self-Destruct'. On site diagnosis is required to determine what components are affected. Best case is a burned out door switch, worst case is a burned out control. Find a good tech to check it out. And avoid the self clean 'feature' unless you have an extended warranty. Too many people believe the salesman when he says; "Clean? Just touch this button!"  Let me know if this explains what has happened, and if you need more info, just ask. Thanks-- Ed
Mar 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Thermostat shows hot, burns oil
Try replacing the thermostat, it sounds like a lack of water circulaton.
Ed
Apr 30, 2009 | 1986 Honda Civic
Low beam headlights don't work
I have e-mailed you 2 .pdf files, one is the complete headlamp diagram, and the other is the relay locations. Please advise if you need further assistance.
Toyota Ed
Dec 31, 2008 | 2005 Toyota Corolla
McData ED 6064
If user names have not been established, you can use the default user
name (Administrator) and password (password). The user name and
password are case-sensitive.
Oct 20, 2008 | McDATA ED 6064 Enterprise Director...
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Lakewood Oil-Filled Electric Radiator Heater Logo
Top Lakewood Heating & Cooling Experts
Mack Baxter
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
