Question about Emerson Audio Players & Recorders
Digital numbers not working
Radio works fine, but numbers are weird looking and have wrong time
'89 S-10 Blazer/Tahoe package. Digital insrtument works sometimes and sometimes it flickers in and out. I sent it off to be referbished but still having the same problem. Here is were it really gets weird,...
I would recommend looking closely at your illumination circuit. There is a gray wire that if shorted could prevent the digital guages from displaying. I would look at the radio connections, especially if you have an aftermarket radio. Also, look around the lighter and maybe a bad dimmer switch.
To trace the problem with the horn fuse, look for shorts in the orange wire. Common places are around the radio or the screws that secure the panels under the dash (floor lights on the dome circuit).
As far as the no start, sound like old and dirty terminals and/or cables.
Dec 22, 2013 | Cars & Trucks
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
HOW DO I CODE MY RADIO ON MY 98 BEETLE ?, I THINK IT HAS A 99 RADIO THOUGH, ITS TAPE DECK TYPE.I HAVE THE CODE BUT IT DOESNT WORK, IT WORKED FOR MY FRIEND LAST TIME , BUT HE SAID HE CANT REMEMBER EXACTLY...
I SOLVED MY PROBLEM WITH MY RADIO , WHEN IT READS (SAFE) , HIT PROGRAM BUTTON , THEN NUMBERS 1000 SHOWS UP, THEN PUNCH IN CODE # FOR YOUR RADIO, AND THEN HOLD RIGHT SIDE OF SEEK BUTTON DOWN FOR ABOUT 2 SECONDS , THEN YER ROCKIN , HA,HA, ENTER THE WRONG CODE MORE THAN 2 TIMES AND YOU GOTTA WAIT FOR AN HOUR FOR THE UNIT TO UNLOCK , SO YOU CAN TRY AGAIN , BUT THE WHOLE THING TAKES 5 SECONDS
Jan 13, 2010 | 1998 Volkswagen Beetle
No regular speaker sound but nothing is wrong with speakerphone
Back up any saved music/sms/contacts/pictures/videos onto a pc
(you shouldnt lose them but just incase)
1. Phone Settings.
2. Security
3. Code is the last four digits of your phone number (unless you have changed it personally)
4. reset settings
Jun 06, 2009 | Samsung SCH-u740 Cellular Phone
Ive got a factory radio reading of i have code how do i reset to put in code
When you turn on the radio, it will say "codE" on the display. You have the 4-digit code number for your radio, to enter the first digit, press the "1" button on the radio the number of times until the first digit matches. For example, if your code is "2156" then, press radio preset button 1 two 2 times, then press radio preset button 2 one time, then radio preset button 3 five 5 times and finally preset button 4 six times.
THEN if the display is correct (should show 2156 in this example), press TAPE button. You should hear a beep and the radio should be working. If you make a mistake and enter a wrong code, the display will show "Err". You have 3 tries to get this correct or the radio may be toast. These are the steps for the stock radio in my 1995 GSX and they've worked for me each time I've lost battery power. Good luck!
Apr 09, 2009 | 1995 Mitsubishi Eclipse
Radio Dead
When it comes to independent auto shops, its tough to get them to take responsibility if they did something wrong, thats why most people with a car as nice as your wouldnt trust it to just any shop. Theres nothing in a timing belt job that would cause the radio to stop working, unless some connector is loose or a bad ground somewhere. There are 3 fuses you may want to check... Radio No. 1 20A, Radio No 2 7.5A, Dome 7.5A. These all send power to the radio's circuit. If all 3 are good, It would have to be an internal problem in the radio.
Jan 25, 2009 | 1997 Lexus LS 400
Samsung 226bw weird display problems
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Nov 20, 2008 | Samsung 226BW Monitor
Corrupt images
Try updating firmware from canons website under support fixes all sorts of weird problems
Oct 02, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Phone switches off when dialling a certain number
looks to me like maybe an update to your mobile may have gone wrong and I have a samsung 370 and nokia 5200 and my samsung freezes and turns off wen i view a picture sometimes my samsung has been damaged so that may be the problem with yours please reply... :)
Apr 02, 2008 | Samsung SGH-D900 Cellular Phone
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
