Question about Hisense Televison & Video
Flat screen tv water damage - Hisense Televison & Video
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
Dec 10, 2015 | Vizio VF550M 55 in. LCD HDTV
My daughter just spayed water on our 52" Emerson led TV, the screen was showing a white vertical band on the right side and could still hear sound. I unplugged and used my hair dryer. Help!!
You may have to take the TV apart to get it dry. You may end up having to replace the screen if parts have been damaged by the water experience.
Jun 01, 2015 | Emerson Televison & Video
Ln46c630k1fxza
You likely got water on the LCD display panel's driver board. The only thing you can do without spending a lot of money is to take the set inside and allow it to dry for a few weeks. If you are lucky enough that no circuits were damaged, the lines will go away. If you are unlucky, the circuit was damaged and the replacement circuit/display panel is as much as buying a new TV.
Nov 08, 2013 | Samsung LA40M81/BDX 40 in. LCD TV
Cleaning
If water have entered inside the panel, you have to disassemble the set's panel to wipe it out. Normally, there is no possibility to enter water into the panel. Anyway, it will be best to contact any service technician. Disasembling panel is a skilled work.
May 23, 2013 | LG 42 42LK450 42 LCD TV
I have a large spot on the right side of the LCD screen, it looks like a large water spot does it mean the VIZIO TV is going out? What can I do to make it disappear.
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen panel itself to causing colors picture pixels and it radiation to died to causing this problems.Sorry it time to buy a new tv,because by replacing the tv LCD screen panel itself will cost u the same as a new tv.Tries buy a new tv from the VIZIO tv corporation directly return the damages LCD panel tv to them,u could get a 5 or 10% off of the tv prices.
Jun 05, 2011 | Vizio VU42L 42 in. LCD TV
How do I clean the screen?
Disconnect the power to your TV before you clean it each time.
Choose either lukewarm water or a cleaning solution to clean your TV. Commercial cleaning kits that include both a cloth and cleaning solution are available. These cleaning solutions are specially formulated to clean flat screen TVs and monitors safely and are specifically labeled safe for "laptop screen" or "LCD screen." If you wish to use a solution, you must use one of these.Dampen a soft cloth (preferably chamois, micro fiber or 100 percent cotton) with either the lukewarm water or cleaning solution. Just a gentle wiping of the screen is enough. Rubbing, scrubbing and hard pressure can damage the screen.
Mar 15, 2011 | Televison & Video
How to clean screen
Use a fine rag and water ONLY. Windex will ruin it.
Jun 30, 2010 | LG 42LC2D 42 in. LCD HDTV
WESTINGHOUSE FLAT SCREEN TV
Water damage/stains possible on backlight panel behind LCD panel. I've seen this more on laptops. Does it look like brighter white spots? You might have to take it in to have it professionally cleaned.
Apr 23, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Water Damaged lcd tv?
Hi there.My 3yr old son water gun our 50" lcd tv sony bravia.I nearly have a heart attack.LOL.There were black mark at the bottom of the screen and when I touch it it's moving around.I realize that it was the water.So I didn't do anything.When we don't watch tv I turn it off from the wall.I kept doing this and after two weeks I notice that the black mark has gone.I don't why>So may be you could just leave as it is...good chance it may to away itself.I hope this helps.thanks.
Mar 23, 2008 | Televison & Video
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
