Question about Sewing Machines
Bernina 820 reviews
Tension adjustment don't work
4 Suggested Answers
  • 17 Answers
SOURCE: I have a Bernina 340 Deco and need to adjust the
Turn the little screw on the bobbin case.
Posted on Aug 15, 2010
  • 166 Answers
SOURCE: How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
Posted on Mar 12, 2012
  • 166 Answers
SOURCE: Bernina 820 Tension Error Message
Jimmy is absolutely right - the 820/830 are very difficult to set-up correctly and you need to find a properly trained Bernina tech to do the job if the machine is in need of servicing. One thing I would suggest, however, is thatyou play about with the spool holder to make sure that the thread is running smoothly into the machine in the first place. It is very sensitive to having any 'pre-tension' and I have found that, occasionally, on a 'marginal' machine, if you use a well-used spool of thread. some spools catch the thread as it is leaving the spool and creates a jerky tension before the thread even passes through the internal tension mechanism. Try varying the angle and height that the thread guide comes to the thread spool and see if that improves things at all. Also, just check the overall thread tension balance by using two colours of the same thread top and bobbin - the bobbin thread colour should only be seen below the material and the spool thread above. If there's an imbalance, so one thread is appearing alot on the opposite side of the material, you can try increasing/decreasing the bobbin tension using your universal tool (white handle). Open the bobbin door and put the notch of the tool on the pip above the bobbin holder and move it a couple of clicks to the right to increase the tension, just to see if this improves things at all. Your machine probably would benefit from a service anyway, but it's worth just checking this out first.
Posted on Aug 28, 2012
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
Bernina Deco 330 embroidery machine bobbin case tension.
There are tests to perform for testing and adjusting bobbin tension. There really aren't any "specifications" other than adjusting it until the bobbin drop test is where it is normally recommended.
adjust bobbin tension Google Search
P.S.--be sure to ALWAYS raise the presser foot when threading the upper thread to insure the thread seats completely in the tension disk.
Aug 22, 2016 | Bernina Sewing Machines
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
I would like to hear about other owners of the 880 and what problems they have had.
BERNINA 880 Review ' Sewing Insight
www.sewinginsight.com/bernina/bernina-880-review/ Mar 12, 2015 - A site visitor asked for a review of the BERNINA 880. ... Usually, machines that sew at speeds up to 1000 embroidery stitches per minute also come with considerably more ..... Beverly Rutherford Brother Innovis 950D Review ...
Sewing Machines >> Brother "The Dream Machine" or ...
sewing.patternreview.com > Forum > Sewing Machines Jan 13, 2015 - 10 posts - ‎9 authors Pattern Review ... Subject: Brother The Dream Machine or Bernina 880 Date: 1/12/15 ... Embroidery/Sewing Combo: Brother Dream machine.
Bernina 880 - Sewing Machines and Patterns Review
sewing.patternreview.com > Forum > Sewing Machines May 9, 2014 - 10 posts - ‎9 authors Bernina 830LE - Brother Dreamweaver VQ3000 - Bernina B530 - Janome ... I just read the manual a bit, then started tinkering and I had a ...
Customer Reviews: Bernina 830 Embroidery and Sewing ...
www.amazon.com/Bernina...Sewing-Machine/...reviews/B0081A3KMQ The 880 also has a stronger/different motor that can run at 1200 stitches per minute ... One is the way the camera works on some of the Brother machines, as well as ... I hope this review helps anyone wanting to buy any sewing machine really.
Bernina 880 - Sewing Machine Review - Top Ten Reviews
sewing-machine-review.toptenreviews.com > ... > Sewing Machine Review Search. Appliances » Other-Household » Sewing Machine Review » Bernina 880 ... Compare to the Top 3 Sewing Machine Review ... #2 Brother PC420PRW.
Best Sewing Machine - Bestcovery
www.bestcovery.com/best-sewing-machine-overall Apr 27, 2015 - Read our reviews to find the Best Sewing Machine and compare photos, specs and user reviews. ... The Bernina 880 Quilting and Embroidery Sewing Machine is ... The Brother XL2600I Sew Advance Sew Affordable 25-Stitch ...
Dec 27, 2015 | Sewing Machines
How do i adjust thread tension
Depends on your Bernina model. Some of the older mechanical models (830 Record, etc), the thread will wrap around a tension knob which you can turn right to tighten or left to loosen. The newer mechanicals, the thread passes through a slot at the top of the machine which is the tension disk, but somewhere nearby there is a dial to increase or decrease the tension. The computerized models, the tension is adjustable on the screen.
Jul 06, 2014 | Bernina Sewing Machines
Bernina nova foot tension adjustment
There is no presser foot tension adjustment on the 1008. Please restate the request as to why you would want to increase presser bar tension.
SewTechnical Home
May 15, 2014 | Bernina 1008
I have a bernina Sport 801 and my bottom tension is off. I'm not sure how to fix this. Adjusting the tension setting doesn't seem to work.
On the bobbin casing is a screw to adjust bobbin tension when upper tension will not solve the problem. Check your manual for location of the screw.
Aug 22, 2013 | Bernina Artista 180
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
May 20, 2012 | Bernina Sewing Machines
Bernia machine tread tension will not adjust
Thread the machine with the presser foot up. This will open the tension control. Set the tension to around 4 and then lower the presser foot to see if this helps. If not, you need a certified Bernina repair person to take a look at the machine.
Mar 09, 2010 | Bernina Sewing Machines
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
