Question about Westinghouse RMT-17
I can't get HDMI2 to display picture. It comes up with no signal and lists add numbers.
Perhaps we hit a strange button? It was working fine before. Everything is plugged in.
My lg 65UF6450 has no TV Guide. It searches for active Channels but finds none. Setting them manually doesn't work either. My satellite TV service is on HDMI2 and works fine, just no TV GUIDE.
I have a TV like yours.
When you hook up an external antennae to pick up over the air channels, the TV will find the channels and display a list.
Your other TV services should come with their own channel guides.
Mar 10, 2016 | LG Televison & Video
Hi. I own an LG 32LC56. HDMI1 port works just fine but HDMI2 produces a "No signal" orbiting message. What can I do?
Main digital board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 28, 2017 | LG Televison & Video
The light just blink green it doesn't let me do anything but blink green.
If you plug the Roku into the back of the TV in an HDMI port, you need to hit the Input button on the TV to change (probably) from HDMI1 to HDMI2. Once you are on HDMI2, you should see the Roku emblem. Then you need to set up the Roku to see your wireless signal.
Dec 16, 2015 | Roku Streaming Stick HDMI Version
Upload pictures to ebay
To add pictures to your listing:
  1. Go to the Bring your pictures to life section on the Sell Your Item form.
  2. Click the Add Pictures button. A pop-up window is displayed that defaults to the Standard tab (the Basic tab will be displayed if your computer doesn't include the Flash software required for the Standard Uploader).
  3. Review your image upload options.
  4. Click the Browse button on the Standard (example A) or Basic Uploaders. This lets you search through your computer's files to find the picture you want to upload.
    5. Select the picture that you want to upload, and then click the Open button (example B).
    The Standard tab page will be displayed with the picture you've selected for upload (example C). Here you also have the opportunity to select additional pictures for upload for a small fee. You can also upgrade your Gallery listing or order a Picture pack.
    6. Click the Upload button (example D).
  5. If you have trouble using the Standard Uploader, or haven't installed Flash, version 9 or later, you can click the Try the Basic Uploader link in the top right to switch to the Basic Uploader.
    The picture will be uploaded to the Bring your item to life with pictures section of the Create your listing page (example E).
    Using the Enhanced Uploader If you are using Windows 2000 and Internet Explorer 6.0 or later, and you have downloaded ActiveX control (you will be prompted to download it if you haven't already), you can use our Enhanced Uploader for faster uploads and more options.
    To add pictures to your listing using the Enhanced Uploader:
    1. To enable the Enhanced Uploader, click the "Add/remove options" link on the Create your listing page.
    2. In the Bring your pictures to life section, click the Enhanced tab, and click the Add Pictures button. The Open screen will be displayed with a list of pictures for you to choose from.
    3. Click the picture that you want to upload, and then click the Open button (example A).
      The picture will be displayed under the Enhanced tab (example B). You can edit the picture by rotating, cropping, or adjusting the contrast and brightness, before uploading it.
      Here you also have the opportunity to select additional pictures for a small fee. You can also upgrade your Gallery listing or order a Picture pack.
    Replacing pictures If you want to replace a picture, first delete the existing picture, then upload the picture you want. If you upload a picture with the same name, both photos appear in your listing.
Oct 03, 2010 | Motorola Mobility Droid X
'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My LG HD T.V wont let me play my playstation
Maybe you've got a wrong menusetting in your Playstation.
Kind regards,
Gerard
Jan 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Unit will not turn on
I plugged in the coffeemaker at an outlet in a different room in the house. Apparently, none of the plugs in the kitchen worked (although) other appliances did work in the kitchen outlets (very strange, perhaps the coffeemaker needs more juice than other appliances) Now I have to have an electrician come out and fix the kitchen outlets...
Aug 23, 2008 | Cuisinart Thermal DGB-600 Grinder
Television picture issues...
I had the same problem when I accidently hit the remote. If you are hooked up to cable make sure INPUT is on the correct setting -- AV, S-Video, YPbPr1, YPbPr2, VGA, HDMI1, HDMI2, ATV & DTV (see button on TV or remote). Hope this solves your problem.
Jul 27, 2008 | Astar LTV-3201 32 in. LCD Television
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Westinghouse RMT-17 Logo
32 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
