Question about McCulloch Garden
Fuel lines fr2.0 model 322503
Route of fuel lines
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
Please refer to your service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Posted on Feb 22, 2018
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: fuel line diagram for 358.352160
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 19, 2009
  • 4088 Answers
SOURCE: route for fuel lines of craftsmen chainsaw
In general, the routing is from the fuel filter in the tank, through about 3 inches of fuel line inside the tank, then through the upper wall of the tank near the carburetor position and up to the top of the carburetor. Don't make any sharp bends in the line or it will eventually kink at that point. The line within the tank should allow the filter to flop around to find the lowest pick-up point as the saw position is changed. If the saw has a primer bulb, it should pull fuel from the carburetor (at a lower port) into the bulb when it is pumped. Another line runs from the output side of the bulb back down into the tank to return fuel (no filter here). Fill the tank with fuel mix and attempt to pump fuel into the bulb from the carburetor (leave the return line loose for a test). If successful, attach the remaining line to the bulb, and attempt start. Hope this helps!
Posted on Apr 29, 2010
puertobori
  • 7733 Answers
SOURCE: fuel lines route for Mac3200 chainsaw
Go To Mcculloch.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
I have 400 arctic cat run till get hot and shut off will not crank until cold what the proble
Sounds like fuel vapor lock. Check routing of fuel line,. Try to route line away from heat as much as possible. If that's not possible, wrap fuel line with heat resistant tape near heat source.
Aug 30, 2017 | ATVs
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
Need a diagram of fuel line
You haven't stated the make and model.. BUT generally IPL's don't show the fuel line routing. Generally the most direct route from tank to carb.
If you need any more assistance feel free to ask
May 24, 2016 | Garden
Polan 3400 fuel line route?
I haven't seen a manual yet that shows you the fuel line route on a piece of equipment.. Generally its the most direct route from tank to carb to primer (if it has one)
May 19, 2016 | Poulan Garden
What is the fuel line route between gas tank and carburetor on 1991 softtail?
Hi Ted, the best route is one that has nice easy bends, no sharp kinking type, and goes as straight as possible directly to the carb, no long downward loop to facilitate an external fuel filter, put the filter above intake manifold. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 24, 2015 | Harley Davidson Motorcycles
I need to run the fuel line from the generator to the fuel tank.
You haven't provided enough information for anyone to answer this: what brand, what model, etc.?
Sep 20, 2014 | Electrical Supplies
How do i route the fuel lines to the carburator ?
Depending on which carb you have it should be the fuel line closest to the bottom on the right side of the carb that goes to the small side of the primer bulb. The long side of the primer bulb will go to the fuel tank as the return line.
Sep 12, 2014 | Poulan Garden
Fuel line routing diagrams for 86 yamaha fz600
You can route it any way you want really. I'm not familiar with your specific model but if you don't have a fuel filter (you should) or a fuel pump to worry about it's just a matter of finding the easiest path from the inlet nipple from the carburetor rack to the petcock on the tank...
That's an awesome number of innuendos in one sentence!
Aug 26, 2014 | 1986 Yamaha FZ 600
Garden Logo
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
