Question about Garden
I have a Craftsman snow thrower. Was running fine then the engine seems to be running erratically. The only time it runs smooth is when the choke is on full or half way. I put new gas in it but it still runs funny.
    Sergeant:
  • 416 Answers
You might have some water in carb
drain the carb run some dry gas for awhile just alittle!
Posted on Feb 02, 2015
2 Suggested Answers
  • 451 Answers
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Posted on Jan 01, 2014
I have a 26 in craftsman snow thrower brand new engine runs erratically hunting
The choke does not have to be all the way open on a snow blower engine. The choke control has notches or steps for that reason. With the engine running adjust the choke one notch at a time until it smooths out. Once the engine warms up you may have to adjust the choke a notch or two to keep it running smoothly.
Mar 11, 2017 | Craftsman Garden
Hello I have a craftsman 123cc single stage 4 cycle snow thrower. . Motor runs great with a little choke. When I put choke off it runs high and low. The spring linkages are moving back and forth
pull the carby and clean out the jets and passages
the carby cannot produce a constant air/f;ow mixture unless the choke is on and the governor is having difficulty keeping the engine speed constant
Oct 19, 2015 | Garden
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
My craftsman snow thrower runs for about15 minutes before it requires more chock until it finally cannot run. Why is this happening
First i would check engine compression. It will change once it gets hot and cause you to use more choke until finaly it wont run.and if that is okay i would rebuild the carburator. A rule i use in my shop is to always check compression first then go from there.
Dec 13, 2014 | Craftsman Garden
Craftsman Snow Thrower engine spews balck smoke
the choke is stuck so remove the cover and look for the choke to see why it,s not movin
Feb 13, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
Adjusting a Craftsman Snowblower Carburetor
crafsman snow blower have choke on to run it
Dec 17, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
