Question about Video Game Consoles & Games
Ps3 error code 8002f07c
Won't let me download a system update
5 Suggested Answers
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: my ps3 wont let me update it ?error code 8002F147
Check your memory status maybe if you delete some old game saves you could have room for the download if that dosent work i suggest you call that number.
Posted on May 06, 2009
SOURCE: Ps3 System Update Failed, PS3 boots with error code 8002F14E.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-When the update begins, pull your HDD out of the slot. It will tell you an error occured and it tells you to restart your system and try again. Instead, let the count from 60 run out, your screen will go blank for about 30 seconds then it will start back up and tell you that your Hard Drive needs to be reformatted. If you do not get this msg after 30 seconds, do it again until it does! Now, slide your HDD into place again - (make sure your controller is PLUGGED IN) and press the white PS3 button on the controller. It will then ask you to either press start and select at same time OR white PS3 Button - PRESS START and SELECT. Do not agree to user agreements!! Simply hit cancel and it will kick back to the PS3 start up screen.
Posted on May 09, 2009
Sutibun
  • 186 Answers
SOURCE: need to fix a ps3 with 8002f1f9 error code. where
PS3 has a **** poor wireless card i would run a cable for your internet connection.You can DOWNLOAD the update and get instructions here
Posted on Jan 22, 2010
How do I correct error code 8002F310
The error code your getting is saying that your PS3 is failing to update. You can disconnect your system from the internet, turn off automatice updates and try it manually or you can try loading the update through the PS3's safe mode. This link will show you how to get your PS3 into safe mode. https://support.us.playstation.com/app/answers/detail/a_id/1488/kw/Safe
Also, you can download the update onto a flash drive and load it onto your system from there. This link will explain how to do so.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Nov 04, 2013 | Sony Playstation 3 (PS3) Console
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Jan 04, 2011 | Belkin N1 Vision Wireless-N Wireless...
I've gotten the error code 8002F14E after upgrading my ps3 to the latest version. system update stops at 68% and then this error pops out.
It is because you don't have the blu-ray drive connected that is making this fail. Hook it up again then try to update. If it doesn't update that way try downloading from Sony's site to a USB drive and update that way. If the laser is bad on the drive you may just want to get Sony to repair/ replace it, even if out of warranty as that is still cheaper than buying a new system.
If you cannot get to any menu to tell ps3 where it is to download it.
Then go to System Update but just tell the PS3 to go for an external device instead of looking for it over the internet.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Need to fix a ps3 with 8002f1f9 error code. where
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 error code 8002F1F9
this error code is due to internal error caused by us ............
ERROR CODE 8002f1f9
has a solution you can download the repair guide to fix this.. your problem can be solved to do so ...... Click Here to Get Solution .......
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Keep gettin error code 80710723 when updating system on ps3
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
I have had PS3 for 3 weeks. The first week PS3 worked fine. Then I received messages asking me to download update data. The only game that askd me to do this was FIFA09. The PS3 alway's crashes when I get...
I have to say I haven't had lot of joy downloading this particular update directly to PS3 either.
The alternative approach (which worked like a dream for me) is to use your pc to save the update onto a memry stick, then to plug that into one of the PS3's USB ports and do the update from there.
There's a detailed explanation of how to do it towards the bottom of
http://uk.playstation.com/help-support/ps3/system-software/updates/
A.
Dec 03, 2008 | Video Game Consoles & Games
PS3 80 GB - Error Code 8002991
Hi tomdonnatim,
If your PS3 is brand new, you most likely have to update the system's software to a more current version in order to properly play many Blu-Ray discs.
In order to update your PS3 system:
Go to the home menu, move to the "Settings" tab (the 2nd tab from the far left), scroll down to "System Update". It takes about 5 minutes to download and fully download the update, but it should solve the problem.
More information on the system update can be found below:
http://www.us.playstation.com/ps3/about/systemupdate
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
265 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
