Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave does not heat - GE Spacemaker JVM1640SJ Microwave Oven
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Most likely one of the door switches. If the fan runs then the magnetron is bad
Posted on Sep 23, 2014
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
SOURCE: My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Posted on Mar 19, 2009
localwonder
  • 6784 Answers
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Posted on May 29, 2009
Ge spacemaker microwave won't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
7sfy
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave #JVM1650WB008 is not heating.
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have ge spacemaker microwave heats but fans dont come on .
This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Feb 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turns on but does not heat
if your microwave does not heat up when turned on its maybe the coil is burnt out are fuse broken, so check your dealers
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
